Speedo
Speedo
So driving home from work the other day I noticed my speedometer stuck at 79. The digital readout works just fine, I DID try the search, but couldn;t find to much, I assume it is the VSS. That being said just checking if anyone else had the same issue and if yall have any remedies. If it matters she is a 2012 P car. Thanks!
'13 C63 AMG P31
https://mbworld.org/forums/c63-amg-w...ck-jammed.html
https://mbworld.org/forums/c63-amg-w...ck-140mph.html
https://mbworld.org/forums/e-class-w...sn-t-work.html
Suggestions seem to be, "smack it" or "go faster" lol. You will probably need to replace the instrument cluster. You can maybe try disconnecting the battery to see if it will reset it.
