check engine lights
I also got an oil change with oil filter and intake filters and spark plugs about 300 miles ago
These probably are the most common codes on the M156 platform. If you read the forums you'd find plenty and plenty of threads.
Smoke test the intake manifold for leaks. Could be:
1- intake manifold gaskets
2- PCV
3- internal intake manifold leak (corrosion)
4- Front timing-cover breather pipe
5- low fuel pressure
Good luck
