Does anyone have a good website to order new lights for the facelift w204 63? I have a 2012 c63 and I need new front headlight LEDs for the lowbeam lights. Im looking to get most likely 6k lights. Thanks for the help
Are you talking about bulbs? Do you have halogen headlights or HID headlights?
Neither will work well either LEDs, you need to replace halogen headlights with new HID housings or some DEPO projector housings and use HIDs for best performance.
I believe I have the bixenon HID. Im not too sure on the specifics
So then you buy new HID bulbs if you 1: have a burnt out bulb, or 2: if your bulbs are a few year old and have a decent amount of use on them.
changing bulbs wont get you much of a cooler colour temp due to the frensel projector lens on your headlights, but if you want a decent increase in output with a cooler temperature your best bet for current high performing bulbs are Osram xenarc cool blue boost.
These are the lux increase on mine as well as showing the colour difference.
Do they have anything in 6k temp? If not then I'll definitely order those.
