Blown differential?
C63 AMG w204
Blown differential?
I have a ’09 C63 with LSD. Today I was on a drive, ESP off and manual shifting. Did a pull and half true first gear I heard a bang! and lost the power to the wheels. Engine fine, could shift from D to R, N and put first gear in from C. But get no power to the wheels. When in D the car can roll backwards. No fault lights on dash. When in D I hear a ’metallic’ rough sound from the rear end.
May it be a blown diff? Driveshaft? Rear axle?
Received 2,827 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Broken axle. Likely drivers side right at the carrier.
In my case it was running toyo R888r's driving kind of stupid. It was about 20* F outside, I hammered on it knowing the tires would easily spin, then they got warm and dead hooked at around 20mph while the tires were moving about 40mph. Snap goes the drive shaft. It broke in the middle section where the splines slide in and out. Solid chunk of metal snapped. Really impressive. I've never seen an amg or any other merc do it. I kept it as a trophy.
Mrplett4 (08-22-2022)
