C63 AMG (W204) 2008 - 2015
High pitch whine on idle (m156)
Old Sep 9, 2022 | 09:17 AM
Drifter2090's Avatar
CLS63 AMG, E92 M3
Hey guys, I'm getting a high pitch whine on my car when idling, I've circled the area it's coming from. Engine cold or warm it's there 90% of the time, some rare times it doesn't make the noise. I have no codes and it doesn't seem to affect anything performance wise.
When I turn the car off the whine slowly fades away, it doesn't instantly stop. Car has new pulleys and a belt.
What do you guys think? Vacuum leak maybe? Secondary air?
Video:
Whine Noise
Old Sep 9, 2022 | 09:32 AM
AMGSIXTHREE's Avatar
'09 C63 AMG
Video:
Whine Noise
You've circled part of the power steering reservoir. They're known to have issues with the filter getting clogged, which causes a whine. I would start by replacing that.
Old Sep 9, 2022 | 09:35 AM
CLS63 AMG, E92 M3
Okay thanks ill take a look at the reservoir tonight, it does get quieter when I move the steering wheel (which is usually the opposite of power steering issues from my past experiences).
Old Sep 9, 2022 | 12:15 PM
'09 C63 AMG
P/S noises usually get louder as the pressure increases (when the wheel is turned) but in this case the increased pressure may help overcome the restriction of the clogged filter 🤷🏽‍♂️
I haven't dug too deep into this issue, but it seems to be a common one for this engine and seems to be fixed for most people by replacing the reservoir.
Old Sep 12, 2022 | 08:10 AM
CLS63 AMG, E92 M3
Ordered a new reservoir, ill also check the vacuum lines in that area. Will update the thread after
Old Sep 12, 2022 | 04:58 PM
eightysixtuned's Avatar
W211 E63 AMG
the power steering reservoir has a filter in it which over time gets gummed up and causes whining. if you're moving the steering wheel and it gets quieter, that could be the issue. will wait for your report back.
Old Sep 12, 2022 | 05:10 PM
CLS63 AMG, E92 M3
Yeah crossing my fingers that it's just that, will keep you posted.
Old Sep 12, 2022 | 10:04 PM
See63Run's Avatar
2013 C63 (W204)
exactly this. I had the same noise when i got my c63. bought the replacement kit (reservoir + fluid) from FCP Euro and it fixed the issue. Be absolutely sure to flush ALL the old fluid out until only new fluid is in the system. They provide enough fluid in the kit for a complete flush. I jacked up the front of the car so that I could turn the wheel lock to lock to perform the flush.
Old Sep 12, 2022 | 10:05 PM
CLS63 AMG, E92 M3
Perfect, and yeah I'll make sure to hook the return up to a bottle and get as much old fluid out, thanks!
Old Sep 13, 2022 | 02:36 AM
Dogtag114's Avatar
2009 c63
This happened to me and it was the secondary air system. One of those little hoses had a small crack that could only be seen while manipulating the hose. Inspect them very closely.
Old Sep 13, 2022 | 06:53 AM
CLS63 AMG, E92 M3
Did you replace them with oem lines? Or did you just use aftermarket vacuum lines? Mine do have cracks on them as well.
Old Sep 13, 2022 | 12:27 PM
Dogtag114's Avatar
2009 c63
I simply unplugged it, confirmed it, superglued it to see if that worked, applied some pressure while it dried and it never came back. I was also getting a secondary air system CEL code occasionally.
Old Sep 13, 2022 | 12:29 PM
Dogtag114's Avatar
2009 c63
You said it also happened warm so I doubt it’s the secondary air. I think that is only engaged during warm up.
Old Sep 13, 2022 | 12:48 PM
CLS63 AMG, E92 M3
Yeah it happens 99% of the time, cold/warm doesn't matter. I will check the lines anyways when I do the PS reservoir. Thanks for the suggestion!
Old Sep 13, 2022 | 02:21 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
When the vehicle is idling and the noise is present, remove the oil filler cap. If the noise goes away then your problem is in the PCV system, which is located on the rear passenger side of the engine. I've done a few for the whistling noise.
Old Sep 13, 2022 | 02:46 PM
CLS63 AMG, E92 M3
Ah okay ill try that, I know the PCV was replaced last year but it seems they installed it without removing the intake manifold, so maybe they didn't do it right? Ill check and see.
Thanks!
Old Sep 13, 2022 | 06:41 PM
See63Run's Avatar
2013 C63 (W204)
i very recently had to diagnose a high pitch whine that disappeared when i pulled the dipstick. i knew mine was intake related but didnt know where. check my recent posts if it ends up being an intake/vacuum issue for you.
Old Sep 14, 2022 | 08:04 AM
CLS63 AMG, E92 M3
Thanks, yeah I saw someone talking about that before too, I'll check it out.
My cars all torn apart right now for the headbolt job, once done I'll check all these, appreciate it everyone.
Old Sep 24, 2022 | 10:51 PM
CLS63 AMG, E92 M3
Finally finished headbolts, gonna change the power steering resovoir tomorrow.
Old Oct 3, 2022 | 07:24 AM
CLS63 AMG, E92 M3
Issue is fixed!! I changed my intake manifold gaskets and replaced the pcv, most likely was the gaskets slightly leaking. So happy it wasn't something weird.
Old Oct 3, 2022 | 08:34 AM
See63Run's Avatar
2013 C63 (W204)
excellent. Always rewarding to fix a problem on your own.
just out of curiosity- did you see a lot
of carbon buildup in the heads and on the valve stems? I had a thin film on mine but it came off easily with some carb cleaner and a soft rag.
Old Oct 3, 2022 | 08:39 AM
CLS63 AMG, E92 M3
Yeah definitely, after doing the headbolts and lifters and fixing this whine, my engine is super smooth!
Not really, they were fairly clean, my car has 224k km on it too.
Old Oct 3, 2022 | 09:45 AM
Dogtag114's Avatar
2009 c63
Post a proud video. With so many “does this sound bad” videos, I forget what sounds good.
