c63 p31
c63 p31
Hi guys, can i change from 235/35/r19 ,255/30 r19 stock to 245/35/r18, 265/35/r18 ? I want to do this for a better ride quality and will this change result in drop of ride height and will it rub ?
Watch your offsets on the 18" wheels and you should not rub and the ride height will only increase about 5/32". The ride quality will probably not change enough to justify swapping out wheels and tires but up to you.
The front tires should be 245/40/18 and not 245/35/18.
I running a 265 Pilot all-season on my stock 18" in the rear. Not sure the height, but it doesn't rub.
You should check the measured width on the tread as some 255s are actually as wide as some 265s or damn close to it.
