Torque Specs HELP
C63 W204
Torque Specs HELP
Serpentine Belt Guide Pulley Torque Specs needed.
Would anyone kindly be able to help me with the exact torque specs of the following 4 guide pulleys in changing with my belt. My tensioner is fine so I'm not replacing it. I've searched around here and getting conflicting info. Some day 20Nm others say 25Nm. I assume blue medium threadlock also?
C63 W204
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
Thread lock will impact the torque setting slightly vs dry torque, locktite recommendation is to reduce torque 20% when torquing with a lubricant vs dry. Mercedes doesn't call for a thread locker but if it makes you feel better using some just reduce your torque settings a little so you don't over torque it due to the reduced friction of the liquid thread lock. If you use the paste I think you can use the full torque values.
GMcCrossan (02-23-2023)
