C63 AMG (W204) 2008 - 2015
Help Navigation
Old Mar 4, 2023 | 01:32 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
Help Navigation
Please help. I tried to install the 2019 nav update. It was going fine then at 46% it said can’t update. So I removed the disc. And now when you turn on nav it says insert disc # 1 and I can’t make it go away. Would like to at least nav the go back the way it. I tried unhooking the battery, and that did nothing. I tried the search and that didn’t help either. Thanks in advance for any help.
Old Mar 4, 2023 | 02:25 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Sounds like you bricked it. Take it to the dealer.
Old Mar 8, 2023 | 06:16 PM
I tried again. This time with the battery fully charged and everything off. And had it hooked up to the battery tender. Took about two and half hours. It works great and now has all the newer roads that weren’t on the 2010 disc. The newest disc is 2019.
Old Mar 8, 2023 | 09:04 PM
Mort's Avatar
Old Mar 21, 2023 | 07:10 PM
I have an extra set of the latest update 2019 if anyone needs a set.
The set I have will only work with 2008 -2011 c class cars.
