C63 AMG (W204) 2008 - 2015
Auxiliary Oil Cooler Fan Delete
Old Jun 21, 2023 | 07:41 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
I read a lot of detached info on this and it's not quite talked about much.
I believe the BS cooler is larger and doesn't have fans. There was mention with the optional cooling package that it might not either?
Either way, the fan seems quite disruptive in terms of airflow. I thought I read that people have deleted it - is that true?
That way the air can flow directly to the cooler. [Yes, I don't have larger radiator upgrades for cooling, but this seems like it would maybe *marginally* help in slow traffic, which I never have.]
Old Jun 21, 2023 | 08:33 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Opposite.
The fan is specifically for stop and go traffic to move air through the cooler when you're moving slowly. Removing the fan will help when moving fast and pushing it since airflow through the cooler will be increased.
Old Jun 21, 2023 | 10:18 PM
Adi-Benz's Avatar
Originally Posted by Jasonoff
Opposite.
Yeah, perhaps I phrased it badly but that's what I meant. I don't really face much stop and go traffic, so wondering it it's more effective to delete it. Surely, for short periods if there is traffic, the system can sustain itself?
Old Jun 21, 2023 | 11:03 PM
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
If you live up north you might be fine deleting it, in the southern states your oil temps would over heat quickly sitting in traffic in 90* F weather.
Old Jun 22, 2023 | 08:21 AM
Adi-Benz's Avatar
Guess I'll try it.
I'll take a look at threshold values and monitor the oil temperature and report back eventually.
Old Jun 22, 2023 | 10:38 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Are you having an issue with oil temps? If not then don't touch it.
Old Jun 22, 2023 | 12:01 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I’ve had that fan fail before. In NYC summer traffic the coolant temp would spike pretty high (260F+). I wouldn’t do it without the larger aux cooler.
Old Jun 22, 2023 | 05:38 PM
AMGSPY's Avatar
2014 C63 507 Coupe
X2 on what sickSVT, Jasonoff and BLKROKT said.
Old Jun 23, 2023 | 04:56 AM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
I removed my auxiliary fan when I fitted SRG C63's bigger front oil cooler and sitting in Summer in Sydney peak hour traffic sits on 105C.
Yes it goes higher when pushing the car especially in manual mode.
Old Jun 26, 2023 | 11:50 AM
Nathan Grimmer's Avatar
I have removed the whole oil cooler and fan, and just use the front one, not noticed any difference in temps at all
Old Jun 26, 2023 | 01:28 PM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
Now that's an interesting. Has anybody done something similar? I would have imagined that the MB engineers thought it was necessary, so engineered this solution in the build.
Old Jun 26, 2023 | 04:03 PM
Elemento Tuning's Avatar
SPONSOR
I can see removing the fan, but an extra radiator with no change? That seems unlikely. You have the stock front?
Old Jun 26, 2023 | 04:27 PM
BLKROKT's Avatar
That was a terrible and odd choice to make. Good luck.
Old Jun 27, 2023 | 03:06 PM
If its just a daily its fine... Mine been off for nearly a year, we also had 38 degress days here last summer, the difference on the dash oil temp was no different.
I just joined the two oil pipes together where the old cooler was.
But I have had many high power turbo cars in the past.. I've only ever upgraded to a oil cooler of the size of the one in front bumper and you see similar on other modded cars..
I also believe some later models don't even have the aux oil cooler it was omitted at factory.
Im only saying mine has been fine without it for normal driving. And because mine had a stone through it and Mercedes told me 3 months and £1100 so as its just a daily run around to get work car it's not a major issue for me
