W204 C63 ESP, ABS Traction Inoperative
Edit: Problem solved! It was the abs module. Replaced it with a brand new one from Mercedes.
Hey everyone! I am randomly getting the eps not available traction, Power Steering, ABS, EBD, EPS, Run flat indicator and cruise control. I have changed both the front abs sensor, brand new from mercedes, battery and driver side can bus driver side underneath the carpet and Abs module was sent to ECU testing and came back not faulty. Vehicle is a 2008 C63
Considering all the things going haywire were very similar to mine, here's my cause and solution: https://mbworld.org/forums/e-class-c...ike-again.html
