C63 AMG (W204) 2008 - 2015
Coolant (325.0 replaced by 325.5)
Old Sep 23, 2024 | 11:45 PM
  #51
H danielle's Avatar
E240 w210 year 2000 v6 2398 c.c
Originally Posted by BLKROKT
You are mistaken. The latest AMG Emergency Service Bulletin (ESB) says to put a gallon of Mobil 1 5W-30 in your coolant reservoir to lubricate the water pump and radiator bearings. I would do it right away to avoid catastrophic failure. Good luck.
it is the first time to hear something like that but may be why not ..but if we do it for how long we leave the oil in the coolant and after removing does the cooant needs flusing ??
Old Sep 24, 2024 | 02:19 AM
  #52
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Yep. I’m sure of it now. This guy is totally an AI bot. No human is this dense.
I’ve unwittingly invented the modern day Turing Test.
Old Sep 24, 2024 | 03:34 AM
  #53
DRBC43AMG's Avatar
That's the best tip I've heard since some time
Old Sep 24, 2024 | 03:47 AM
  #54
H danielle's Avatar
After anvestegating i think you are totally wrong about that info
Old Sep 24, 2024 | 05:31 AM
  #55
H danielle's Avatar
Old Sep 24, 2024 | 09:00 AM
  #56
BLKROKT's Avatar
No shít Sherlock
Old Sep 24, 2024 | 09:01 AM
  #57
BLKROKT's Avatar
I love this. Please post more nonsensical bullshít, this is starting to get good.
Old Sep 25, 2024 | 04:18 AM
  #58
DRBC43AMG's Avatar
To get the coolant clean, I wonder what rating MB gives to bleach?
Old Sep 25, 2024 | 01:25 PM
  #59
1Lop2K5C's Avatar
C63
Perhaps unrelated topic, but can one still use the pink 325.5 stuff along with Water Wetter?
Old Sep 25, 2024 | 05:35 PM
  #60
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Why would you do that? The coolant itself does everything that WatterWetter does six times better... the only time you'd need WaterWetter is if you're not allowed to run coolant (when racing for example).
Old Sep 26, 2024 | 08:39 PM
  #61
deadlyvt's Avatar
2010 C63 AMG
The diesel version helps with cavitation and high is of benefit in the cooling system... not needed true but can help with heat transfer within the engine to the coolant.
Old Sep 26, 2024 | 08:46 PM
  #62
Diabolis's Avatar
When you're running pure distilled water, then yes, it helps. If you're running coolant, you're just unnecessarily diluting it and making things worse. Coolant has considerably better heat transfer, anti-oxidation, anti-bacterial and anti-cavitation properties that WaterWetter.
Old Sep 27, 2024 | 10:07 AM
  #63
fflmlf's Avatar
2013 C63
Old Sep 27, 2024 | 02:47 PM
  #64
deadlyvt's Avatar
2010 C63 AMG
Trying to find a video but can't seem to find it... I believe it was by banks diesel they had a coolant pump attached to a pipe into a box that heated the pipe. The heater and pump were set at max and the same for every test. The temperature of the fluid changed depending on what the fluid make up was. The higher the temperature of the fluid the better the fluid was at absorbing the heat from the heater. The used an oil, pure distilled water, distilled water with I believe water wetter or something similar, 50/50 coolant water mix, and a 50/50 mix with the watter. The result was water on its own would boil near the edge of the pipe where the heat was being added and not absorb as much heat, as when it had the wetter substance. It took in a lot more heat than just water. True the 50/50 coolant mix didn't change as much as just water, but it did still improve it a bit. Is it needed, no factory coolant/antifreeze is designed pretty good to be a good coolant and not freeze. But in the test I saw it did improve it slightly... obviously if you want maximum cooling a pure distilled water with something like water wetter will be your best bet.
Also the smaller the orifice the more micro boiling/cavitatstion the fluid would experience in relation to volume so depending how the vehicles internal cooling routing is would also play a significant role
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
