3D-Printed Product Line now Available
I just don't like the "turn" lights programming on these cars (ex. when turning left the left fog turns on). So I just turn them all on. I usually do that anyways with my c300, but with this one I can't seem to do only eyelids with fogs, I need to have lowbeams on to turn on foglights. Is is the same for everyone else?
The benefit of this is you are able to remove your auxiliary fan in front of the cooler, as it is not as effective as it may seem.
Not only does it block a significant amount of fresh air, but it only mildly helps if you are idling for a long time after an intense run. While moving, it negatively impacts temperature when compared to open intake.
That said, if you sit in 1 place in stop and go traffic, in hot climate areas, removing the fan / this modification will likely not be for you.
Either some trimming or removal of the left vent will need to be done to allow the fog as an inlet.
This is a somewhat bad photo but it's slightly farther throw and clearer.
