C63 AMG (W204) 2008 - 2015
Low coolant, smoke start up, weak cold starts.
Old Dec 5, 2023 | 07:43 PM
JoeyIppolito's Avatar
2009 C63 AMG / 1925 Ford Model T
Car was low on coolant, topped off and did oil change. Low on coolant again. Started having smoky startups, sat for a week and blew a large cloud. Last two start ups were cold starts and sounded super weak, about half the sound as normal.
car has 56 K miles 2009, could I be horribly unlucky with headbolts?
Here’s a cool pic at least
Old Dec 5, 2023 | 08:04 PM
Joshinator99's Avatar
ML 63 AMG
Originally Posted by JoeyIppolito;[url=tel:8887862
8887862[/url]]Car was low on coolant, topped off and did oil change. Low on coolant again. Started having smoky startups, sat for a week and blew a large cloud. Last two start ups were cold starts and sounded super weak, about half the sound as normal.
Any coolant in the oil (or vice versa)? Could do a cooling system pressure test to confirm the issue but sounds pretty clear cut unfortunately.
Old Dec 6, 2023 | 03:29 AM
Madcow554's Avatar
2012 C63 P31 and 2011 E550 Luxury
You could have a bad cat
Old Dec 6, 2023 | 08:21 AM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Someone is sneaking your keys!
Old Dec 6, 2023 | 10:16 AM
GarlicBread's Avatar
AMG C63
Unfortunately, yes, its looking like your headbolts are done.
After 15 years, mileage starts to matter less as distance and time are relative in regard to wear and entropy.
I wouldn't start it anymore, and I'd start taking things apart if you have the means to do so, not sure what your garage has.
Otherwise, take it to a MB or reputable shop.
Old Dec 6, 2023 | 10:18 AM
ML 63 AMG
I see what you did there… 😂
Old Dec 6, 2023 | 04:03 PM
It’s in a friends shop right now, having no mixing of oil and coolant is what made me confused but we’ll see.
Old Dec 10, 2023 | 11:41 AM
HLG600's Avatar
2009 SL63 AMG
A visual inspection of the oil doesn't give you the complete picture. It could seem like there is no mixing to you but a lab analysis of the oil will show otherwise.
Hopefully nothing else was damaged and your friend's shop can get you back on the road without issue.
Old Dec 10, 2023 | 12:56 PM
Steven_C63's Avatar
w205 c63
just because a head gasket is blown doesn’t automatically mean coolant and oil will be mixing. It could be blown in a way where coolant enters the chambers but not in the oil passage way.
Old Dec 11, 2023 | 10:37 AM
6_Myles's Avatar
1998 E300TD
Mine did not mix on my head gasket failure(s).
