C63 AMG (W204) 2008 - 2015
Mercedes Benz C-Class Upgrade Wireless CarPlay--Carlinklife
Old Jan 1, 2024 | 08:28 AM
Carlinklife's Avatar
Former Vendor of MBWorld
Carlinklife Apple Carplay/Android Auto Integration kit for Mercedes-Benz W204 (2008 - 2015)
Our Apple CarPlay/Android Auto integration kit will give you the ability to add on functions for Apple CarPlay and Android auto to your Mercedes existing entertainment system. To control and switch the apps within Carplay, is integrated with your vehicle’s built-in controls, or with your voice thanks to Siri/Google Assistant. You will not lose any functions from your original system, the integration kit will work as an added function. The kit will come with the required module and all the necessary wires to complete installation in your vehicle.Version 2 Improvements:
– Improved C-class specific screen resolution
– Wireless Android Auto is now supported
– No need for a separate microphone for Siri or Google Assistant, now works through the original car microphone
Features of our kit:
– Wired/Wireless Apple CarPlay
– Wired/Wireless Android Auto
– Easy control with vehicle built-in controls
– Sound is played through the vehicle’s original Aux or BT Media Interface sound source
– If your vehicle has original Rear View/Surround View cameras, those will continue working the same way
– This module can be extended with Front/Rear view camera (if your vehicle didn’t come with those originally from the factory)
– The installation is completely plug & play and 100% reversible.
Link:https://carlinklife.com/products/wir...reverse-camera
Discount code "mbworld"
Old Jan 2, 2024 | 09:30 AM
tian647's Avatar
c63
NTG 4.0 features/compatibility
The linked product does show a selection option for NTG 4.0 as on the earlier cars (2008-11), but in all the copy details only 4.5 and above are referenced.
Can you confirm this solution also works with NTG 4.0, or if there are limitations what specifically is changed or lost?
Thank you!
Old Jan 12, 2024 | 08:06 AM
Thank you!
NTG4.0 and NTG4.5 are compatible with the same package and have the same functionality. There is almost no difference in usage.
Old Jan 12, 2024 | 08:15 AM
The installation method of C-class NTG 4.0 (2008-11) is the same as that of Ecclass W212 (NTG4.0&4.5).
You can view this thread:https://mbworld.org/forums/e-class-w...play-w212.html
Old Jan 12, 2024 | 08:57 AM
tian647's Avatar
c63
Appreciate that, hadn't previously heard they were so closely compatible/functional.
