M156 P0300 Misfires when warm
Been waiting to post this for 2 years. Always hate when people open a thread and then don't post a solution, so if you didnt watch the video, it is summarized below:
Root cause: Improper clearance from the front-most cam bridge on bank 1 causes inadequate oil pressure to the cam adjuster, leading to misfires once the ecu tries to control timing.
Not sure why, but after i intially throught the cam bridge that i checked tolerance on and replaced had not fixed the issue, i drove the car hard for 15-20 minutes, reset the ecu, plugged the cam solenoid in, and boom. No more misfires. Car has been driving perfect for 3 weeks and ~500 miles now.
So in the end, this was a self-inflicted issue. The cam bridge that I broke 3 years ago and then replaced with one with unknown tolerance caused all of this. Hindsight being 20/20, i probably should have been suspect of this sooner, but whats weird is it took almost 10k miles for this issue to show up, so i didn't put 2 and 2 together.
Hopefully someone someday learns from this, but unless you break a cam cap, maybe not! Onto the next project....
