Engine mount Help
Engine mount Help
Question:
For the Driver side engine mount, can I loosen the engine mount where it connects to the block? If so what needs to be moved out of the way to best facilitate this and what are the torque specs?
Even with the 16mm offset tool, the top nut is tucked under the exhaust because the mount has failed.
