Strange sound when acceleration m156 (video YT)
the problem started after entering the vehicle where the entire exhaust system with catalytic converters comes from. The bracket is 100% OK. Be a manager in a professional workshop. It seems to me that the outlet is also well sealed, although it may be too tight because at low speeds (800-1000) it is sensitive to slight shaking. It's definitely not the alternator or the power steering pump or any pulley because it's the same without the V-belt. What comes to mind is either a leaky exhaust somewhere between the exhaust manifolds and the catalytic converters, or I'm unlucky and accidentally have a leak in the intake manifold. Do you have any ideas ?Video YT: https://youtube.com/shorts/ZQv4EiHNF1Q?si=q2kUS_u2fcSsP9OF
