The indicator switch has stopped cancelling when turning and I suspect needs replacing.
Being a c63, it has the electric steering column position switch incorporated into the indicator stalk/sqib.
Does anyone know if you can replace just the indicator switch part from a non electric steering column indicator or do they have to be replaced as a complete unit.
Have attached photos of a standard and non standard stalk/sqib assembly, first has no electric adjustment and the second has the electric adjustment swiych. Hopefully the above makes sense!
