C63 AMG (W204) 2008 - 2015
Heavy power steering
Old Jul 20, 2024 | 12:40 PM
wheelspk2131's Avatar
c63 w204
Hello,
My c63 power steering feels heavy, i have changed the Steering Reservoir bottle new oil but its still feels heavy, what can i do to fix this?? Pump dieing?? But it has no winning now it used too then i got adviced to change oil made no difference
1 week ago my AC cooling coil went bad had to remove the dash to replace it after that power steering been heavy
Its like driving a truck, my power steering is like working 50% its not super heavy but heavy enough that i start sweating
Let me know any solutions please !!
Old Jul 22, 2024 | 01:34 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Since this happened right after work was done, it’s 100% the speed sensor on the top of the transmission has been unplugged or the wires cut or something. Start there.
Old Jul 23, 2024 | 03:15 AM
c63 w204
shouldn't that had thrown a cel ? But ill check that the power steerings works but its heavy like i feel its working 50% lol
anyways ill check and report back
Old Jul 23, 2024 | 08:25 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
No but the module would have a code stored. It's electronic hydro assist so the hydro assist is variable. If you unplug the connector at the rack (which I do for the track for better steering feel) no CEL just the module stores an open circuit code or something and the assist is much lower.
Old Jul 23, 2024 | 02:03 PM
c63 w204
Thanks guys problem solved , the angle sensor was not at zero , after we zeroed it put the power steering is soft again
Old Jul 24, 2024 | 09:42 AM
SteeleyAMG's Avatar
C63 AMG
How did you zero the sensor? I have an odd low speed heavy steering feel after some routine work that didn't touch any steering stuff.
Old Jul 24, 2024 | 11:40 AM
c63amg204's Avatar
w204 c63 amg
Use a scanner tool possibly xentry and go to power steering setting and zero it out you can find many videos on YouTube on how to do it im sure OP did the same, was your steering taken off? Thats the only time you might have to zero it again,
have you tried changing the oil reservoir? It has. Filter that clogs up new oil is the pump making any unwanted sounds?
