M156 intake manifold map sensor port picture
If anyone has a m156 intake laying around that can remove the map sensor from the front right corner and shoot me a I picture of the hole/port in which it enters the manifold I would greatly appreciate it. Thank you in advance
I am in the process of replacing my M156 intake (due to corrosion) , here are some photos:
Old M156 manifold from 2007 ML63
New M156 manifold.
Side Note: I have encountered an issue with the new manifold after installation, I was getting a CEL with P0106 B28 error code, implausible pressure.
I removed the MAP sensor, hooked it up a large syringe , and pulled a vacuum on it while running a scan tool, pressures changes seemed OK. I then used that same large
syringe to check if air freely moved in/out of the MAP port. It moved freely in the old manifold, but it is blocked in the new manifold. That explained my B28 code..
Syringe used to test MAP sensor and port.
Borescope image of MAP port in old manifold. Not sure where the access channel is to the inside of the manifold.
Maybe a vent channel has become corroded? I guess I will take apart the old maniifold to see how the MAP sensor venting works.
New M156 manifold.
New M156 manifold.
New M156 manifold.
New M156 manifold.
New M156 manifold.
blackdeathc63 (09-30-2024)
