C63 AMG (W204) 2008 - 2015
2010 Mercedes C63 Intake Manifold Blew Up
Old Mar 8, 2025 | 04:29 PM
escobar6.3's Avatar
C63
My Intake Manifold blew up. What would the next step be for me other than changing the manifold.
Old Mar 8, 2025 | 08:52 PM
PHILLYCLSJOE's Avatar
2002 CLK55 AMG: 2004 S55 AMG: 2009 C63
I've never seen anything like that happen before. Any idea on how that happened?
Source a used one and rebuild it on the bench, then replace it.
- Joe
Old Mar 8, 2025 | 08:58 PM
escobar6.3's Avatar
C63
- Joe
I’m not entirely sure how, but I was driving home one day and my car lost all its power and I barely made it home. I was left with an engine code. The intake manifold pressure sensor has a malfunction. So it could either be the sensor or the timing of my car I assume. Since it back fired.
Old Mar 8, 2025 | 10:12 PM
roadtalontsi's Avatar
10 C six trizzle
"What would the next step be for me other than changing the manifold?" Do nothing and either park or sell the car as is broken needing the intake manifold replaced. lol.
Old Mar 8, 2025 | 10:17 PM
escobar6.3's Avatar
C63
haha lol. Go kick the biggest rock you can find. lol.
Old Mar 8, 2025 | 10:57 PM
duuder's Avatar
500E - CLK BS
holy sh*t... WTF
Old Mar 9, 2025 | 05:23 AM
DRBC43AMG's Avatar
Never seen that before
Old Mar 9, 2025 | 07:29 AM
LSAMG's Avatar
2013 C63 AMG Sedan
ECS Tuning last year New $4000.
Old Mar 9, 2025 | 10:13 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
First one I have ever seen do that, the concern here would be tracking down why it happened if it literally has never happened to anyone before, just sticking another one on it may result in the same if you don't understand why it happened and even used ones are not super cheap to do that experiment on.
Old Mar 9, 2025 | 02:55 PM
Big Worm's Avatar
C63 507 Coupe
That's crazy! I agree with Rob, you need to understand the root cause before you have an expensive repair suffer the same fate.
Something detonated, as evidenced by the smoke and the overpressure needed to split the manifold. What cause it?...I don't know. Intake valve somehow open during power stroke?
Old Mar 9, 2025 | 02:58 PM
Jvand's Avatar
happend to me with a car that i was working on some year ago, but with mine the cracks where at the bottom plate also because of a backfire. But that was my own fault (the backfire)
i might be able to help you with a used one (the upper piece that is broken) but im living in europe not sure how sending it works.
Old Mar 11, 2025 | 12:24 AM
10 C six trizzle
You could also put a blower in its place. 2 alternative solutions provided now, why so mad?
Old Mar 11, 2025 | 11:27 AM
HLG600's Avatar
2009 SL63 AMG
Wild stuff. Important to figure out what caused this because despite all the M156 intake manifold issues that people have been dealing with the over the years, the top shell blowing apart has not been one of them.
Over-pressurization can be a cause but if it was coolant / cooling system / head gasket related, there are other components that would fail first. Even if that pressure made it to the IM, I would expect those aluminum-foil bolts to fail well before anything else.
Too much oil and a completely overwhelmed PCV could also be a factor. Are you sure the engine wasn't over-filled at the last service?
Old Mar 18, 2025 | 10:36 AM
Hopkeye's Avatar
2013 c63
Holy F*ck lol.. has the cause been determined yet?
It’s hard to believe this would be an over pressurisation event, because there are so many other parts of the manifold that are much weaker than that section.. The bottom pan is thin magnesium that regularly blows out (usually from corrosion though) the Y-pipe plenum that leads to the filters is just held on by 2 plastic clips. I would assume back pressure would blow that off long before that section. Even the plastic filter housing is brittle plastic. The PCV is also notoriously soft, and should have blown off the back if none of the previously mentioned options did not… I’m really curious on this one man
Any update?
As far as replacement, I checked a couple months back and you could still order a new I.M. From Mercedes for around 2k. Before shipping/tax. No idea how long the wait is tho. I don’t think it’s something they have sitting on the shelf. Needs made and shipped from Germany if im recalling it correctly.
Old Mar 18, 2025 | 12:12 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Where's the nitros lines hiding? lol
Old Mar 18, 2025 | 07:54 PM
yfz rock's Avatar
2011 raptor 2010 C63 AMG P31
No better reason to buy a supercharger than this no question.
Old Mar 29, 2025 | 03:20 PM
escobar6.3's Avatar
C63
The engine wasn’t overfilled the last service. The only engine codes I had were the ones below. I ended up buying new camshaft position sensors, that didn’t end up fixing it.
-The intake manifold pressure sensor has a malfunction.
​-The position sensor for the intake camshaft (cylinder bank 1) has a malfunction.
-The position of the intake camshaft (cylinder bank 1) deviates from the specified value
Old Mar 29, 2025 | 03:43 PM
escobar6.3's Avatar
C63
Any update?
As of now i’ve found a replacement Intake Manifold. I’ll also be retiming the car because that’s what most likely caused it to blow up in the first place.
Here are the codes that I had.
Old Mar 30, 2025 | 07:22 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
That's pretty wild. I've seen the plastic manifold blow up but not on a metal one.
Old Mar 4, 2026 | 03:45 AM
Oli63's Avatar
Have you fixed it?
Have you managed to fix it? If so what was the internal damage? I’m looking at one currently with the same inlet manifold damage. It’s also now not starting since it’s had the manifold replaced
