M156 Engine Oil Temp Sensor
I'm looking for some advice on replacing the engine oil temperature sensor on my W204 C63 Coupe.
After a hard drive, I noticed that my oil temperature readings started fluctuating and aren't staying consistent. I suspect the engine oil temp sensor might be faulty.
I've been having a hard time finding clear instructions online for this job. I understand that the sensor is located behind the AC compressor.
Is this a job that can realistically be done on a driveway?
Also, is the coolant temperature sensor located nearby, and would it make sense to replace it at the same time?
Thanks in advance for any help!
Technically you can do it in a driveway, but the compressor has to be degassed and removed to access the temp sensor.
You may be able to put it on a lift with supports for the engine and drop the subframe slightly to get access.
I don't have access to a lift so I can only jack the car up on the drive.
also is the coolant temp sensor in the same area, I know the coolant and engine oil temp sensor share the same part number?
Crazy huh?
https://mbworld.org/forums/c63-amg-w...-location.html
