C63 AMG (W204) 2008 - 2015
P0456--- Evap code that goes nowhere
Old Feb 11, 2026 | 04:04 PM
Bimbonot's Avatar
2009 C63 AMG
Angry P0456--- Evap code that goes nowhere
Check Engine light - code reads Po456 Evap leak ---- Changed gas cap and purge valve --- did smoke test --- nothing --- what is left. I inherited car from my son who was a fanatic about upkeep. At the mercy of mechanic. Just a Mom who wants to keep the memory of her son.
Old Feb 12, 2026 | 04:59 PM
AMGSPY's Avatar
2014 C63 507 Coupe
Did you try clearing the code to see if it comes back? Someone here with more knowledge than me will weigh in. Good for you to keep going with his car that I'm sure he loved.
Best, Don
Old Feb 13, 2026 | 08:58 PM
SICAMG's Avatar
2005 e55 AMG
Sometimes the smoke test needs a higher pressure in the system to reveal a leak when they are really small. Many many times at the dealer I worked the smoke test took some playing around to actually find the leak so maybe try again.
Old Feb 14, 2026 | 12:30 AM
roadtalontsi's Avatar
10 C six trizzle
Sorry to hear about your son but I'm sure he'd love knowing you're trying to keep his baby on the road and enjoying it. There isn't too much to the system but very fine leaks can be a pain to find. I'd remove the back seat bottom, open up the fuel pump / filter access ports and check for signs of external leakage. Next would be to smoke test again with the passenger fender liner removed. During smoke testing you will need a scan tool to close the charcoal canister shut off valve if it still leaks than that's your issue. Those are the 2 most common places. Aside from that either a hose/line is cracked has a pin hole or the fuel tank itself. 95% of the time its a fuel sending unit or a charcoal canister on this model.
Old Feb 14, 2026 | 10:35 AM
Bimbonot's Avatar
2009 C63 AMG
Thank you
