Camshaft lifts over .500" on m156/m159?
They would have to bring a spare set of heads/block to them so they can spec out a set of cams with compatible springs and check for all clearances.
IIRC, when I installed my custom cams there was very limited room with lift before having to do major head work for clearance.
I started asking around because for this other import application the heads were flowing 210cfm@.300" lift but 265cfm@.400" lift. The stock cam in that situation is only .309" lift so getting .450" lift is worth over 40HP with no losses on the curve.
For the M156, when looking at the Flow data for the stockers and ported Weitec's i was interested in spending time past .500" lift perhaps .550" lift. It'll also sound more aggressive.
Flow numbers:
Lift Stock Weistec ported
.200" 202 205
.300" 300 318
.400" 348 372
.500" 358 389
.550" 359 398
Webcams says the stock specs are:
.469/.435" lift, 11.9/11.05mm valve lift with 215/213@.05" and 233/232 advertised duration
For a .500"-600" lift setup you'll most likely have to pull the heads and do some grinding so the added lift clears the heads.
Then you'll have to spec out a set of compatible valve springs, check for valve to piston clearance, ect. Also, not many tuners know how to properly tune a set of big lift cams for this platform.
It's much easier if you're local to a shop like Comp Cams where you can take a spare set of heads and block and let them do all of the work.
entire head package you're easily looking at 8k without yet porting the head. then you also might want oversized valves of which may or may not be included in the 8k ballpark. just really depends where you source your parts. what i can share is, a member who had their head built with custom dual valve springs had a few of them snap and i bet in less than 3,000 miles of usage.
I checked on the SLS forums and i can't find one post where someone went after higher rpm and more flow out of the heads... Someone must have chased 10,000+ RPM out of the DOHC as pushrods are doing up to 12,000 RPM.
A real RPM cam on these DOHC will be 240-250 @ .050" on pushrods the .050" is up to 280-300 duration.
Intake:
- Lift: .469"
- Duration: 215* @ .050"
- Lift: .435"
- Duration: 213* @ .050"
The SBF guys couldn't run too many RPM because the "long runners" of the cobra and gt40 style intakes limited them to under 5800 rpm.. The long intake runners boosted off idle and low end torque, but the harmonic resonance didn't work at higher rpm and shut down the power...
SBF guys had a mindset that had them at .525-.550" lift on short durations... The Chevy LS guys "weren't scared" to run cams over .600" lift for the street. Usually .600-.625"... That extra almost .100" lift gave them increased torque and hp over the SBF guys.
So.. Even in 3.0-3.5L V6 engines with DOHC. When they have weak lift cams of sub .500" lift, getting an additional .100" lift and keeping duration the same gives an additional 25-30HP without ported heads.
On the wonderful 6.2L AMG C63 with the great flowing heads a extra .100" lift will probably give an easy conservative 50HP increase while keeping power band the same. This is important because the C63 ( non-SLS ) intake shuts down power before 7000... While it gives more rpm than a "cobra" or "gt40" style intake on a original ford 5.0, if you tried to get 7000+ rpm out of it it will shut down on power, because it's tuned for power under 7000 rpm.
