S or non-S?
I was under the impression front and rear were creamic. the only difference with the E63 being the sliding rear caliper vs 4 pistons.
One copper caliper is $1000 so $2k for the front.
Actual front rotors for the E/CLS/SLS are close to $3k each. Rear are $2.5k each.
Based on E63 S CCB parts…
Front pads $255
Front rotors $2265 ea ($4530)
Front caliper $915 ea ($1830)
Rear pads $195
Rear rotor $2100 ea ($4200)
Rear caliper $675 ea ($1350)
Total - $12,360
Now as a factory order lets remove the factory steel brakes…
Front pads $295.50
Front calipers $780 ea ($1560)
Front rotors $750 ea ($1500)
Rear pads $213
Rear calipers $461.25 ea ($922.50)
Rear rotors $140.25 ($280.50)
Total - $4771.50
Difference between the two is $7558.50, with $6949.50 of that being the price difference of the rotors. Now I know production costs are much different than anything in the retail world and there may be other costs involved but it gives a good idea of the cost difference in the actual brake hardware.
But the almost complete lack of brake dust and the fade free performance (so far) in situations where my C63 brakes started feeling stressed have sold me on them. Also I think the AMG version of CCB are the best feeling and least touchy of the ones I've driven, mainly those from Porsche, Ferrari, and Lamborghini granted I haven't spent as much time behind the wheel of those as I have my AMG.
Can you please expand a bit re: the performance of your CCBs in the rain? I read an account from an F8X owner (his car has CCBs) and he said that the CCBs became scary in wet conditions. He mentioned needing to mash the brake pedal to the floor to be able to stop from relatively low speeds.
Of course, this could be a BMW-specific CCB problem. Or, that particular owner could have a problem with his CCBs.
Front pads $255
Rear pads $195
Total - $12,360
Front pads $295.50
Rear pads $213
Total - $4771.50
Looking make the jump from BMW to MB.
My dealer doesn't have exact pricing they can share with me quite yet, but the general consensus is that the C63S will be around $10k more than the non-S?
What's everyone ordering here? Originally I was thinking of getting a non-S and just hopping it up with aftermarket, but I don't want to get the runt of the litter if the norm is to get the S. Re-sale would be a problem...
So S or non-s?
And what's the story with Edition 1? Is that the equivalent of a "launch car" complete with bugs and QC issues?
Thanks in advance.
(oh, I should mention I am in the USA).
Todd
The AMG high-performance brake system has the following components:
- on the front axle: integral brake discs measuring 360 x 36 mm, internally ventilated and perforated with 6-piston fixed calliper
- on the rear axle: brake discs measuring 360 x 26 mm, internally ventilated and perforated with 1-piston floating calliper
- grey-painted brake callipers with white AMG lettering
AMG high-performance composite brake system** : (red)
Greater fade resistance, lower weight
Large, internally ventilated and perforated brake discs all round provide for excellent deceleration. The composite technology at the front increases fade resistance and reduces weight. The reduction of weight lowers the unsprung masses on the wheel, thereby improving the response of the spring/damper elements and overall stability.
Features of the AMG high-performance composite brake system:
- Front axle: composite brake disc measuring 390 x 36 mm, internally ventilated and perforated with 6-piston fixed calliper
- Rear axle: brake discs measuring 360 x 26 mm, internally ventilated and perforated with 1-piston floating calliper
- Red-painted brake callipers with black AMG lettering
Edit: so the S is an unbelievable deal. It explicitly includes $4k-$4.5k in optionable features, then on top of that +35hp, elec slip diff, and dynamic engine mounts.
