C63/C63S AMG
Built-in turbos?
Old Mar 6, 2015 | 10:24 AM
jimc63s2k16's Avatar
16 C63S
Built-in turbos?
Sounds scary repair bill wise. Has this type of setup been proven reliable?
Old Mar 6, 2015 | 10:52 AM
PeterUbers's Avatar
Do not own this c63 out of warranty!!
Old Mar 6, 2015 | 11:12 AM
Tjdehya's Avatar
2023 AMG EQS
Unless you are mechanic or don't mind high repair bills, then Do not own any MB out of warranty.
Old Mar 6, 2015 | 11:21 AM
RPM99's Avatar
2012 Mercedes C350 Coupe
Extended warranty usually takes it to 7 years?
Old Mar 6, 2015 | 12:04 PM
MB Dave's Avatar
Suzuki Burgman Executive
Do not own a AMG out of warranty!!
FTFY
Old Mar 6, 2015 | 12:19 PM
PeterUbers's Avatar
+1000
Although with all the electronics in our cars these days .. It's cost prohibitive to own many different types of cars out of warranty
Old Mar 6, 2015 | 12:43 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
We shall see soon.
Old Mar 6, 2015 | 12:51 PM
MB Dave's Avatar
BMW uses a similar set up in their M5 and I haven't heard of too many complaints. I know its not fair to compare separate brands but you are asking if this setup is inherently troublesome.
Old Mar 6, 2015 | 02:01 PM
InfinityWind's Avatar
Range Rover Sport Supercharged - Porsche Caymen S - Motorcycles
I think that the engineering concept is quite safe and common, saying that I think that if they have any issue it will be due to location of the turbo's and the excessive heat that it generate after hard runs and when the car come to a stop.
Old Mar 6, 2015 | 02:38 PM
skullboy's Avatar
Porsche 981 CS, C450, 3000GT VR4
Turbo timer ???
Old Mar 6, 2015 | 06:20 PM
zibby43's Avatar
'20 GLC300 SUV
The intake design on the W205 is pretty darn robust, fortunately. The A-wing front splitter also helps to force feed air into the engine when the car is at speed.
Old Mar 6, 2015 | 10:12 PM
JPMBenz's Avatar
17 C63 S Coupe
My BMW 335xi N54 twin turbo 6 had 2 Divertor Values with a charge pipe. I'm curious on how the Air/Boost upgrades will work. The CLA 45 does have a upgraded POV value.
Old Mar 6, 2015 | 10:28 PM
PeterUbers's Avatar
Originally Posted by skullboy
Turbo timer ???
Not necessary these days... But I remember when everyone was driving 300zx's and supra's they all had those
Old Mar 7, 2015 | 12:03 AM
Merc63's Avatar
C63 AMG
What's a built in turbo?
Old Mar 7, 2015 | 01:11 AM
zibby43's Avatar
'20 GLC300 SUV
An interesting way of referring to the "hot v" turbo configuration.
The turbos are mounted inside the V of the engine, rather than on the outside.
Old Mar 7, 2015 | 10:58 AM
Merc63's Avatar
C63 AMG
Ok, so why is everyone worried about this? This makes repairs easier if they pop out the top.
Old Mar 7, 2015 | 12:07 PM
Tjdehya's Avatar
2023 AMG EQS
beacuse they want to get an early start on "monday morning quarterbacking" the MB engineers decision to place the Turbos in such an unorthodox place.
Old Mar 7, 2015 | 02:12 PM
zibby43's Avatar
'20 GLC300 SUV
I'm not worried about it all. The F10 M5's S63tu motor has been using this same configuration.
Old Mar 7, 2015 | 03:56 PM
Merc63's Avatar
C63 AMG
So does GM on their duramax diesel for a decade. Works fine there and is easier to work on then pulling them out the bottom.
Old Mar 8, 2015 | 08:30 AM
g-f's Avatar
g-f
996TT
Isn't the warranty on these 4yrs 80,000km? Why worry about hypothetical repair bills that could happen somewhere in 2019?
Because AMG has put the same engine in the top of the line AMG-GT, I believe they tested the ***** out of that set up and are confident in the design.
Old Mar 8, 2015 | 06:12 PM
zibby43's Avatar
'20 GLC300 SUV
Also a good point. The M177 and M178 are essentially two CLA45 engines spliced together.
And the 2.0L 4-cylinder in the CLA45 has 360 bhp. The new M177 is going to have major power potential. I'm guessing we'll see it in the new E63.
Chris Harris insinuated that it is capable of well over 650 horsepower.
Old Mar 8, 2015 | 06:47 PM
Will617's Avatar
2016 C63S
It would be interesting to see if the E-AMG's are going to stick with the 5.5tt or downsize to the 4l tt.
Old Mar 8, 2015 | 06:50 PM
abcut973's Avatar
They will with the new E63.
