Configurator is up
http://www.al-lighting.com/press/sin...0738c80087a183
Same goes for some of the Euro. weight specifications.
With all the mistakes and build errors on MBUSA I will remain confident about it being lighter than the w204 until somebody puts one on a scale and proves otherwise.
87k usd the way i wanted it....be better off getting an edition one for 88
Either way, I'm happy with the car.
Motor Trend tested the W204 C63 507 Coupe and it weighed in at 3,952 lbs.
http://www.motortrend.com/roadtests/...son/specs.html
I think the standard W205 C63 will weigh somewhere between 3,750 and 3,850 lbs. It will continue to be a guessing game until an owner puts one on the scales.
I've weighed my LCI W204 C63 before and it came in at approximately 3,820 lbs.
FWIW, I predicted the F80 M3 to weigh in at around 3,600 lbs. We've seen F8Xs around/slightly under that mark (e.g., a CCB-equipped M4 @ 3579 lbs; a CCB-equipped M3 @ 3562 lbs).
One important thing to remember in this discussion is that while weight alone is important, so is power-to-weight ratio. While the F8X platform will likely retain a 150-200 lb weight advantage (at least), both C63 variants are cranking out more hp/tq.
It's also unfortunate that it doesn't use a real DCT, and based on Chris Harris's review (and knowing the MCT) it isn't quite as snappy as the DCT found in the M3. DCT's are really the only way to get anything nearly visceral from a transmission now that manuals are pretty much going extinct. I don't see suspension options so I'm assuming it's one standard suspension designed with several different active settings.
I also wish automakers wouldn't con you with their irrelevant hard drive navigation systems by "forcing" you to pay the exuberant prices just to get the better screens. Though I think the massive tacked on faux "iPad" on the C dash is a practically comedic fad of a design flaw (unfortunately trending across many cars currently), architecturally speaking, it's of a better resolution, etc. than the standard "whateverAndroid" style screen with the big borders, etc. So you've gotta pay up for things like Navigation, XM, hard drive, etc. which you can get via alternatives by streaming your Smartphone into your system and using a thumb drive. Using Google/Waze/Apple Maps are all superior and instantly updated alternatives to an OEM nav, and can be streamed via BT. Yet car manufacturers still hold some small bait to dangle in front of your face to coax you to pay $3K for a so called "tech package".
My pet peeve with car ordering nowadays is in paying $3 G's for Nav packages for about $100 in hardware I need from it. In the Merc's case, it'd be the higher res screen. I didn't order Nav in my current car and couldn't be happier (fortunately I get the same screen and interface anyway, which isn't important to me on this car, but makes it an easy decision anyways). Streaming Apple Maps or Waze through my BT with Siri Voice Control beats the Nav and connectivity experience I had with my Merc's or recent iDrive. And I just had to save $3K to get it.
Now the question is, do I really need an AWD C400/450 or go with another 63. Hmmm........
A tank of gas is 100lbs too...
I also believe someone has already predicted the S model will out sell the non-S model. We shall see if this works. It certainly has worked on me.
Here is Dan's video
Here is Dan's video
https://youtu.be/JhjUJTw2i1M?t=12m10s
Mercedes has been doing that for ever. They always do that on their top models in each class. My dad bought a GL 550 because it had all the options standard that werent standard on the GL 450. At the end of the day it was like a 5k difference but its worth it.
Its kinda surprising that the car is so heavy. Not one reviewer complained about the weight
Everyone complained about the RC-F.
Everyone complained about the RC-F.I wanna see a Motortrend head2head between the M3 and C63 S, both with fresh tires and brakes, 0-60, 1/4 mile drag, and lap the circuit in the hands of Randy Pobst.
It was a comparison between the standard (non-S) C63 and the M3.
The C63 won. Link:
https://mbworld.org/forums/c63-amg-c...m3-vs-c63.html
And we have had a review by Henry Catchpole of Evo Magazine as well. Link:
https://mbworld.org/forums/c63-amg-c...catchpole.html
Evo Verdict:
"AMG has got much of the C63 absolutely spot on. There is still the sense that it isn’t quite as tight, focused and involving as an M division car, but it was [n]ever thus and if you’ve experienced the latest M3 on a slippery surface you’d probably argue that slightly more approachable and less spiky car isn’t necessarily a bad thing. The C63 obviously still has to pass the wet bumpy B-road test to see if its 516lb ft can remain friendly, and we’ll bring you the verdict just as soon as we can.
The fact it has monstrous pace, a soundtrack to match and the ability to oversteer with ease, means it has arguably done enough to make it the default choice in the class."
My '13 LCI W204 C63 sedan came to about $72k. It has the Multimedia Package, Iridium Silver paint, the Lane Tracking Package, the Lighting Package, Keyless-Go, AMG Illuminated Door Sills, Wheel Locking bolts, Chrome Door Handle Inserts, etc.
When I built an identically equipped standard W205, the price came out to $72k again.
I selected: Iridium Silver Metallic; Red-painted brake calipers; Multimedia Package; Open-pore Black Ash wood trim and AMG Performance front seats.
I love the way the 18-inch AMG twin 5-spoke wheels look. They look lightweight and strong (plus they show off the brake hardware).
I feel like you get a lot more "standard" with these newer cars. For example, with the W205 you get premium (i.e., non-Halogen) headlights as standard. You get a premium Burmester sound system standard. And so on and so forth. Naturally, these additions serve to drive the MSRP up a bit.
