C63s. Quarter mile
#153
C63 507 AMG DA Car #19
https://mbworld.org/forums/amg-gt-gt...00hp-gt-s.html
Rt st 2----700hp
This is getting interesting gents.
Rt st 2----700hp
#158
Received 2,123 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Slicks....
#160
2012 CTS-V
Nice. That 119 mph trap is very healthy especially in the heat. This car is screaming for a set of drag radials. lol
You should try again in October. I bet you pick up another 1 to 2 mph from the temperature change alone.
For comparison sake my stock CTS-V ran 12.1 @ 119 with a 2.0 60' in October at Atco.
#162
Right lane here.
Ran again last night. Here are the things I changed:
1) 1/4 tank of fuel. Last time I had a full tank
2) Adjusted my seat to be slightly further back; created more leg room so a easier push on the throttle.
3) Tires were at 20 PSI down from 22.
4) Temp at the track was 75.
5) Traction control was 100% off.
60' was much higher then the first runs. I tried using LC but the tires in 3rd broke and the ESP in Sport kicked in. Hence, why that wasn't the faster run.
#163
Contrasting with the tuned C63s run of AMGTTV8 you have high 1/8 mile MPH.... YET lower 1/4 MILE MPH..... must be his tune.
THanks for sharing. I can't wait to get my 1/4 mile run in..... it's 104degF here now..... so no rush on this end.
#164
Wow 12.1 is very good JP, kudos bigtime .
It's amazing to see you run 4/10 quicker but you are 3 MPH slower but as you said the ESP interfered and robbed you. It shows us that there is still some left on the table. I'm sure you are aware of this as well and must be eager to run again. With some practice I believe high 11's and in the 120's should be possible. As always, thanks for sharing.
#165
Actually it works the opposite....the faster the 60' foot the quicker you will get down the track with a lower speed. The speed decreases along the the time. Does that make sense? I feel, all everything working right, 11.8 at 116 is what the car will run. The car truly needs to be driven with the ESP off to gain the full use of the 1/4 mile.
#166
'15 C63S
The need to lower your tire pressure that low doesn't apply to modern-day, low profile street tires.
There are two main reasons why you would significantly lower your pressures:
- To increase your contact patch size. Pounds per square inch (psi) --> lower pressure means you need more square inches (larger contact patch) to support the same weight of the car.
- To allow the sidewall of the tire to more easily flex to 'soften' the shock caused by the launch.
The short sidewall on street tires isn't going to flex at all under longitudinal stress. Not going to happen by a long shot.
As for the contact patch, with the stiff sidewall of modern street tires you can only increase the contact patch so much before you begin to deform that contact patch and make for uneven contact with the road (i.e. the middle of the patch basically folds under and the edges of the patch take most of the stress). If the gas-door pressures say the rear should be 33 psi, I wouldn't go much below 28ish on the dragstrip. Anything lower is counterproductive.
When you enter into the world of drag radials and slicks, the old-school rules still very much apply.
Also, another thing I wanted to make sure of is that you aren't driving through the water box and doing a burnout. The only reason to do a burnout in street tires is to clean them off, but if you just avoid driving through debris you shouldn't have a problem. The little amount of heat you might put into street tires won't make a difference, and if anything you'll end up with trace amount of water in the tread that'll greatly affect traction.
#167
2015 E63S AMG & 2013 GLK350
#168
I think I need a math major to fully understand lol.
I've just learned from experience running the 1/4 mile that when it hooks up my ET as well as the MPH would be better. The first and foremost important part is for it to get traction of the line.
#169
'15 C63S
The more traction you have, the more power you will be able to put to the ground. More power means quicker ET and higher trap speed than with less power. Therefore, everything else held constant other than traction, a car with more traction will have a quicker ET and higher trap speed.
If all you are doing is essentially making you car more powerful by being able to use more of that power, how could it be slower?
#170
If you have a low ET, but low trap speed.... that is high tq.... and falling on it's face on the top end....... or traction issues on the top end (n/l for this car).... or letting off on the top end.
Or if it's an aero dynamic problem...... brick truck type vehical...... falls on it's face up top....... low MPH........
data-logging will unlock some of this mystery.
#171
'15 C63S
Low ET with low trap speed can also be the result of light weight and (relative) low power. Think of something like the Lotus Elise. You have similar power/weight ratio as a heavier, more powerful car, but you have a significantly worse power/drag ratio.
Falls under the same principle as your "brick type truck". Drag kills the top-end performance for both but for different reasons.
#175
