C63/C63S AMG
What to do to make the car track ready?
Old Jul 14, 2015 | 05:40 PM
Promise's Avatar
458 spider / 991 turbo s
The title says it all, I have a 2016 c63 S arriving sometime in the fall and I plan on taking it to a few events once next summer rolls around. What do I need to do to make it ready> I am getting ceramic brakes as they are just too nice.
Thanks!
Old Jul 14, 2015 | 06:36 PM
matt11212's Avatar
Diamond W205 C63s Ed1
You should ask your local track, as different tracks have different requirements. But your car sounds ready to me
Old Jul 14, 2015 | 09:12 PM
Edition1JPA's Avatar
C63 W205 Edition 1
Thanks!
I will be on the track with mine on July 31st and I did an autoX event a couple weeks ago... The car is ready!
Funny when you see everyone working on their car, checking it over, making adjustments. You just show up and hit the loud pedal and you'll be fine!
Old Jul 14, 2015 | 09:55 PM
irablumberg's Avatar
2015 C63S E1; 2016 C450 AMG
Remove all personal items that might fly around under hard braking and cornering.
Determine optimal tire pressures before going to the track and ensure that your tires are at those pressures when you are ready to go on track. Remember, if you drive to the track, your tires will likely not be cold when you are ready to go on track, so determine the right pressure for the tires warm or hot.
Assuming you will be doing lots of laps, fill your tank with gas of known good quality.
Set up your Individual settings as appropriate for the track. If the track is really smooth, you can go S+ on the suspension, otherwise, you should probably stick with S. You probably want Race for the engine / transmission. Set the transmission to auto or manual depending on your taste. If you are new to the track, I suspect auto will be fine as you learn the track (particularly since you can always grab a paddle even in auto mode). Finally, I suggest sport mode for the stability control. It lets you slide around a bit but will save your bacon at the limit.
Enjoy.
Old Jul 15, 2015 | 12:32 AM
C63 W205 Edition 1
Enjoy.
Make my comments look bad. Lol.
Should have provided a bit more info. The pilot super sports run great at 48psi in the front and 45psi in the back... Yea, that is super high but not far off the recommendation on the inside of the door. I found that running a bit higher gave some good even wear on the tire. But you will have to adjust for the track.
Running in race mode isn't too bad. It will still catch you if the back end gets way out of line. Traction control is the same for sport and sport +
Old Jul 15, 2015 | 11:50 AM
RDOCA's Avatar
2016 C63S Sedan
I thought I read that the recommendations on the door frame were only for the EPA and were too high. A car mag. test said to use the numbers behind the fuel door .
Maybe someone with a car can check both numbers and post as my car is not here yet.
Are the numbers you posted cold or hot? if cold they seem high.
Old Jul 15, 2015 | 05:44 PM
SE7ENC55's Avatar
011 gtr
yes that seems WAY too high. Id run closer to 30psi cold. They will heat up quite a bit. Not sure but this has been my experience with my GTR.
Old Jul 15, 2015 | 10:42 PM
AV1's Avatar
AV1
C204 C250-CDI
Out of curiosity are you running air or nitrogen in your GTR's tyres ?? AFAIK nitrogen is specified as standard OEM for this vehicle.
If nitrogen then the tyres will have much better stability and less need for adjustments.
Those pressures specified for the 205 C63 sound way too high even higher than specified for the 204 variants.
I suppose feed back from trials both on road and track should determine what's best.
Old Jul 16, 2015 | 02:57 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Thanks!
With K-MAC you can seize the advantage on or off the track!
....OEM there is only front and rear Toe adjustment!
We saw the need and manufacture for all W205 including C63/C63S precisely adjustable (single wrench on car). Front Camber and Caster and rear Camber (with extra Toe) kits.
CAMBER: Allows to actually change the tire contact angle, improving wear/traction/understeer/oversteer
CASTER: Resolves steering pull, increases steering response. With better turn in and high speed directional control. Along with improved anti dive/lift under brake and acceleration
Set up car for day to day commuter use with precise/ongoing adjustment capability for more even tire wear, traction. Improving cornering response, resolving steering pull. Then ability to re-adjust settings if changing vehicle height, load carrying, fitting wide profile tires, wheels or curb knock damage.
Track days –able to reduce understeer by dialling in (single wrench) extra negative Camber (and track width) to gain more grip/traction – allowing to go deeper into the corners and also hit those corner apexes every time in the pursuit of front row of the grid lap times.
These unique K-MAC patented design front bushes replace the 4 highest wearing suspension bushings and have twice the load bearing area. They eliminate the OEM air voided, oil filled bushes, yet retain 2 axis movement. Result is improved brake, traction and steering response.
Many aftermarket brands also eliminate the air voids but with today’s multi link arms 2 axis movement can be restricted! With the result of actual increasing wheel tramp, loss of traction.
For the Rear –again can adjust for more even tire wear then fine tune for maximum traction on track days.
End of August will also have front replacement top strut mounts for W205 Coil Spring models.
Both Camber and Caster adjustable – The patented design allows quick change of settings from engine bay (no mods to fit).
These kits will be available in Stage 2 – Street/Race, or Stage 3 – Full race versions.
Up to (extra) 3 degrees of Camber adjustment. Made from not soft billet alloy but ultimate 7075 grade.
Also same time will have bushing kit for the entire 12 rear suspension link bushes. Allowing noticeably improved rear end stability, handling response. Allowing to get maximum power/traction to the ground. Overcoming the problem of unforgiving short life delrin bushes that soon pound out.
W205 Front Camber and Caster bushing kit #502816K $480
Rear Camber (and extra Toe kit) #502226K $480
1st Sept front top strut adjusters (Camber and Caster)
Stage 2 (Street/Race) #502816-2L $545
Stage 3 (Full Race) #502816-3L $545
1st Sept Rear 12 link bushing kit #502826K $480
Current promotion for MB World members USA/Canada delivery - $30 one kit or $40 front and rear (normally $70 one kit, $80 front and rear). Can pay by Visa, MasterCard or PayPal.
See link for latest 2015 catalog Audi to Volvo – World’s largest range http://K-mac.com/mercedes/
Old Jul 16, 2015 | 03:22 PM
zibby43's Avatar
'20 GLC300 SUV
Some great tips thus far.
If any of the following has already been covered, my apologies. Make sure you have:
1) Proper tires (and you're running the proper tire pressure)
2) Proper, high-temperature brake fluid
3) Proper brake pads
Old Jul 17, 2015 | 04:31 PM
Promise's Avatar
Will I need new brake pads for the track day?
Old Nov 16, 2015 | 12:39 AM
AMG_Eric's Avatar
2016 AMG C63s
I am assuming if I have the carbon ceramic option the brake fluid should be appropriate for the track.
Old Nov 16, 2015 | 03:43 AM
msk74717's Avatar
CLA45 AMG
At the AMG track day at Bathurst Australia this year the AMG engineers told me they set all tyre pressures to 48 lb all round. They checked it often throughout the day to make sure it wasn't changing too much. They often had to bleed air from the tires after a few laps.
Old Nov 16, 2015 | 10:24 AM
RDOCA's Avatar
2016 C63S Sedan
I wonder if he was talking about the C63S or others as the C63 has a weight distribution of 54% f 46% r and the recommendation for light load and up to 155mph is 38lbs. front and 33lbs. rear. At higher speeds and loads you need to move up but I think the front would still be higher. Up to 180mph and light loads (three people or less) they say 45f and 39 r. With more weight in rear (5 people) they cut differential to 3 lbs.-48f 45r
Remember to only look at the numbers behind the fuel door in the USA as the numbers on drivers door frame are EPA only so they get better fuel ratings and not what you should run.
Old Nov 17, 2015 | 12:55 AM
sighting's Avatar
e63s edition 1
how many laps are you doing?
honestly most track days they do in stints of 4 - 6 laps flat out.
You should be set as is.
Caution to the wise here but depending on your stints and driving style you would almost blow thought a set of tires. and possibly half your brake ware.
Your next track day you will hopefully have learned to drive properly and your consumables will drastically go down.
I can do 10 track days on a single set of tires in a big heavy 4wd 720hp fatty e63s now on a set of tires versus just 3 before. so be safe and have fun and learn...
Old Nov 19, 2015 | 10:50 PM
kfehling's Avatar
2015 C63 AMG S Edition 1, 2021 GLS63, 2020 McLaren 600LT Spider
If you do not have the ceramic brakes like me, check your brake pads often. I burned through mine in two sessions.
