C63/C63S AMG
engine differences
Old Aug 26, 2015 | 08:31 AM
TEAShea's Avatar
2016 C63
engine differences
What are the internal engine differences between a 177 and 178? Does the 177 have a forged crankshaft?
Old Aug 26, 2015 | 08:50 AM
rongpanda's Avatar
2016 AMG C63S
The 178 has dry sump lubrication, allowing it to sit lower in the engine bay.
Old Aug 26, 2015 | 10:21 PM
AV1's Avatar
AV1
C204 C250-CDI
They are exactly the same internal hardware, engine block and heads wise.
The engine internals consist mostly of forged hardware, pistons and rods as well as the crankshaft - the piston assemblies are the same as used in the M133 (ie. AMG A & CLA 45's)
The differences are as already mentioned the dry oil sump system, air intake feed systems and outer exhaust peripherals.
Old Aug 27, 2015 | 08:42 AM
TEAShea's Avatar
2016 C63
Is most the of the power difference due to software changes?
Old Aug 27, 2015 | 10:08 AM
RDOCA's Avatar
2016 C63S Sedan
The C63s has more Tq than GTS and same HP
GTS is lighter.
Old Aug 27, 2015 | 10:31 PM
AV1's Avatar
AV1
C204 C250-CDI
The power/torque output and curve is absolutely governed by ECU programing yes
There'll also be torque output governing and/or control by the TCU ie. the transmission ecu especially in the case of the AMG GT to control maximum torque "through flow".
