C63/C63S AMG
C63 AMG ticking sound
Old Sep 3, 2015 | 04:52 AM
Sulfatron's Avatar
C63 AMG W205
Hi everyone,
I am new to this forum, been following and enjoying it for some time and this is my first post;
I took delivery of my new C63 yesterday and couldn't help but notice a faint ticking noise at idle which I believe is coming from the engine. The noise is only noticeable at idle in a quiet environment (radio off and aircon fan down) and disappears when increasing the rpms.
Has any of you heard this noise with your C63? Is it a normal noise for direct injection engines?
I also notice that when the gearbox goes from 4th to 3rd gear at low speed, the gear change is somehow brutal (as if someone engaged the clutch rapidly in a manual car).
Thanks in advance for your feedback
Old Sep 3, 2015 | 09:53 AM
RDOCA's Avatar
2016 C63S Sedan
I haven't heard it on this car but others I have do it and its the injectors tick.
When you get the hard down shift? are you in comfort and coasting?
The clutch can disengage and reengage roughly.
Old Sep 3, 2015 | 12:27 PM
Sulfatron's Avatar
C63 AMG W205
Well, took the car to the dealership today and they said that the ticking noise is completely normal for this car (something to do with the engine getting rid of gases from the fuel tank).
As for the downshift, yes, this happens when in comfort and coasting. The car is booked for a gearbox software update next week.
Old Sep 3, 2015 | 12:29 PM
RDOCA's Avatar
2016 C63S Sedan
One of the car mags. complained about this and several owners said the update fixed it.
Old Dec 21, 2015 | 08:16 PM
Rorie's Avatar
2015 Mercedes-Benz C63 AMG S Edition 1, 1995 Ferrari F355, 2004 Mini Cooper JCW MC 40, 1967 MGB
What update? I am getting the same ticking noise.
Old Dec 21, 2015 | 09:17 PM
RDOCA's Avatar
2016 C63S Sedan
The update was for the shifting not ticking. Didn't you have it done if I remember?
Ticking might be injector noise.
Old Dec 22, 2015 | 09:34 AM
MB Dave's Avatar
Suzuki Burgman Executive
Like any DI motor
Old Dec 22, 2015 | 03:50 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I think it's the sound of the purge valve ( usually labeled "MOT"). It deals with excessive fumes/vapors in the fuel tank. Mothing to worry about completely normal.
Old Dec 22, 2015 | 05:06 PM
AMG MB's Avatar
SLS BLACK SERIES, G63, S63, C63S, E63S, G500 4X4 BRABUS, PORSCHE 911 4S, FERRARI 599 GTO. RANGEROVER
I HAVE SAME THING WITH MY C63S BUT I GUESS ITS NORMAL..
Old Dec 22, 2015 | 05:14 PM
Nashville's Avatar
2001 E320
the ticking is the direct injection fuel pump that is in the engine bay, completely normal on all 2012 and newer MB's
Old Dec 24, 2015 | 02:20 AM
whitehotC63S's Avatar
2016 Mercedes Benz C63s AMG
I had this issue. Took it to the dealership. They insulated the fuel pump lines coming from the high pressure pimp and the purge valves, said they were resonating against the body of the car. No more ticking.
Old Dec 28, 2015 | 01:31 AM
SBH-'s Avatar
C63S 2016
for the ticking I don't really know about that. BUT for the brutal downshift, I am really disappointed with my gear shifting from 5th to 4th gear and from 4th to 3rd gear. Its really brutal and feels as if there is something wrong with the gear!
Any input guys? Is this normal? FYI the car made 350 kilometers only.
Old Dec 28, 2015 | 02:14 AM
350 is hardly anything. My car was real rough changing gears when I first got it but it smoothed out. Plus the transmission learns how you drive so it becomes much nicer. Once the car is around 3000 KM you should have a differential service that is needed. Mine was at 1,875 miles. Make sure you do it! This cleans out all the metal shavings from the diff and it will perform much better as well.
Old Dec 28, 2015 | 02:23 AM
SBH-'s Avatar
C63S 2016
So this brutal downshift, which makes it seem like the gear is faulty, would ease out with time? It really worries me the shift from 5th to 4th, throws me front!
Old Dec 28, 2015 | 10:09 AM
I mean if it's really that bad I would take it to the dealership. It's under warranty! 😎😎
Old Dec 28, 2015 | 10:35 AM
Rocman8's Avatar
E55
they are clueless. purge valve on modern benz cars dont "tick" anymore. they are designed differently and the make a slight humm/hiss noise and you cant hear it unless your ear is next to it. the ticking noises you hear is the injectors along with the high pressure fuel pump. after they do the software update make sure they actually adapt the gear shift that you are having the issue with.
Old Feb 14, 2017 | 11:14 PM
AmexWest's Avatar
W205 C63S
An interesting idea. Is there any documentation - anywhere - that the transmission is adaptive learning???
Old Dec 8, 2018 | 07:05 PM
Wleuschen's Avatar
2003 SL55AMG
2003 SL55AMG
When my 2003 SL55AMG sits for awhile the right rear corner drops. Only the one corner. As soon as I start the car it levels off nicely.
Would this be a problem with half of the rear valve block? Does the one block control both rear corners?
my MB dealer says to not worry about it dropping while sitting as long as it works while driving.
i just hate to open the garage door and see the car sitting lopsided.
Thoughts?
wm
Old Dec 8, 2018 | 08:27 PM
ScottsC63's Avatar
2015 C63 AMG sedan
I’ve got the 2015 with the original software in engine and transmission no issue at all, I don’t hear any ticking besides the injectors which isn’t loud at all. I’m probably going to ODB port tune so I could careless about the update. Oh and installed the porterfield R4-S pads today brake dust and squeeling is gone!
Ticking is injectors, drive the **** out of the car have some fun with it!
Old Dec 8, 2018 | 10:19 PM
untamedd's Avatar
2019 AMG GT R
i get sort of a hissing sound from my exhaust at times.. something to do with the valves im assuming
Old Feb 14, 2019 | 01:37 AM
hsenadhira's Avatar
w211 E220 CDI
Hi Everyone, Thought to join this forum in order to get some help for my w211 / E220 CDI.
I got this car recently and ran for about few thousand kilometers. I didn't get the repair history and I think i made the mistake of not flushing tranny oil. It was shifting fine and smoothly and even drove without skipping a beat. However, yesterday when i was cruising at about 50 and when rpm goes up I heard a tiny grinding noise which was going up with the engine rev. after few hours it refused to shift from 1st gear. Then after about few minutes it refused to move. I switched off the engine and started, then it was fine for a moment. Again same symptoms came up. Now the car is in workshop, they're also trying to troubleshoot as to what has happened.
Would love if you guys can shed some light on this as i'm completely clueless on what happened which i didn't see coming.
Old Feb 14, 2019 | 03:56 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Hi everyone,
It's normal on some direct injection engines, more pronounced on others. It's normal on these cars.
Old Feb 16, 2019 | 08:27 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
I posted to wrong thread and don't see a delete button. sorry...
