Issue with electric steering? Or is this how it is supposed to be?
#77
2010 BMW M3, 2010 Lancer Evolution X, Incoming 2020 C63S Coupe
Good to hear you got this fixed. If I could ask a favor - next time you get a chance, could you turn your steering wheel to full lock (either direction), let go of the wheel and accelerate at ~5 mph and see if the wheel corrects itself to center?
#78
The dealership have driven it for long enough to witness the issue but so far haven’t found the issue. Has anyone else actually solved this? I’ll report back. IMO it could be dangerous.
#79
I don't have your specific issue, since my steering wheel stays "stuck" while in a full turn-to-lock position. But wouldn't a replacement steering rack have at least been one of the first fixes to perform?
#80
I currently have my 2019 coupe in for this issue as we speak. It’s hard to describe but on certain gentle left hand bends the steering momentarily locks and is reluctant to turn to centre.
Both mine and NYSoil got it resolved with a new steering rack.
I had to push hard to have it resolved...The issue is obvious, but they are just not sure if its the steering rack and reluctant to do anything.
I personally noticed the same issue on another demo MY19 as well. I feel for the person who buys it.
#81
The fault also doesn't register on there scan tool. Hence, dealerships will shy away from doing anything for you.
#83
Hi guys,
just to update. I just got mine back after being at the Mercedes dealer for 5 weeks. I can’t complain about the service I received from them albeit slow but I am disappointed that Mercedes release a new model with so many cars worldwide having this issue! I’m just wondering when the recall will be! Before someone loses control of their affected car.
So after a week of testing, eventually permission was given to change the steering rack (it was on back order for a fortnight). It turns out the new rack they fitted was also faulty! When I enquired it seems it was a reconditioned one that was fitted so for some reason removed steering racks seem to be going back into circulation which I think is worrying!
#84
Anyway, I had the dealership check the alignment when I brought it in for the 10k service and as expected they found both front toe angles out of spec and yesterday I had all four tires replaced with a new set of Michelin PS4S. Wanted to get rid of the PSS anyway. As far as I can tell, all weirdness with the steering is gone, including the steering not returning to center at low speeds. Car drives like a dream now and I'm counting on more grip with the rear tires. Have to break them in over the next 500 miles, but I did some quick pulls on my usual onramp yesterday and where it previously spun the wheels up to third gear sometimes, the PS4S did barely spin. I went with the stock size, but noticed the PS4S seems to be a bit wider than the PSS, so slightly wider contact patch. They look slightly less stretched than the PSS did. Depending on how they perform, I may consider going up to a 295 next time.
#86
I have a 2019 C63s coupe and have definitely noticed something similar.
Only at freeway speeds, the steering sometimes has a weird "heavy" feeling. It has never felt "locked" however if for example you deflect the wheel enough to change lanes the wheel wants to stay in that exact position. It does not naturally return to a neutral position. After changing lanes it takes positive input and more than "normal" return the wheel to centered.
I have raced my car on track in race mode and never noticed it then.
Its odd, intermittent but not alarming or dangerous and I have just chalked it to the electric steering and or some computer function and not a mechanical fault or inherent design fault.
My car does not have any have the electronic "nannies"
#87
You drive an AMG.. The whole damn steering is electric.. so all the feedback is electric lol
#88
#89
I have the exact same issue with my 2019 model. Brought it to the dealership and they could not find anything wrong. The idiot service representative also told me the car had a hydraulic steering rack and then gave me the added insult of trying to explain how a "performance car handles and drives". This is the worst steering I have ever had in any vehicle and AMG should be ashamed of this crappy design.
#90
I went through this with my 2020 63s Coupe. Local dealer changed rack, then pump and finally after 3 failed repairs in 6 weeks the car was lemon'd for a new 2020 which has been perfect. Stay on top of dealer service department and dont let them tell you its fine, cause its not. Stay on it, remember to use key words like 'its a safety issue'.
#91
cheers
#92
im struggling still to get anywhere with mine. What country are you in? I made formal complaint to MB asking to reject the car and they wouldn’t entertain it. Told me to get a second opinion. Do you have any paperwork stating what exactly where the technical issues that can be quoted?
cheers
cheers
#93
Thanks for your reply. Seems like we have suffered the same. Mine is on my third rack and still has the niggle. Expensive to fix, but they are now saying it is and it isn’t. I’ve sat next to the mechanics as it’s done it. They say nothing and then later on I pretty much get told it’s in my head.
So much for the customer is always right!
#94
#96
Hi guys,
I’m struggling to get a resolution with my electric steering not returning to centre intermittently. MB again are saying there’s nothing wrong with it.
Can I canvas opinion from the community as to who still has ongoing and unresolved issues? And who has had it eventually fixed and if so what was the fix in the end?
Mine is on It’s 3rd steering rack.
#97
Mine was repaired twice, its better now but not fully fixed. Dealer offered to dig deeper, take the whole car apart which can takes weeks/months. I said I'll take it back AS-IS for now
#98
So the issue came back and now its even worse than before. Really disappointed with the car at this point. Going to drop it off again, my dealer said they will try their best and they will involve Germany at this time (some new VR technology that they use, they no longer send a representative down). Don't really want to lemon the car, want to keep it for as long as I could being its the last of the V8 and I drove it in Europe... But the car is not drivable and even for me its dangerous to drive.
#99
I have both 2017 F82 M4 Competition and recently purchased 2020 C63s Coupe.
So far, steering feel is definitely my least favorite part of driving otherwise amazing C63.
While both M4 and C63s have electric steering, one on M4 in my opinion is much superior in terms of having that connected feeling.
Omega4 (07-05-2021)
#100
