Burmester stereo settings
Is it because the Burmester system uses smaller speakers and frontbass?
Whatever the reason, I just can't get it to sound "right."
Anyone figured out the best settings to use? In particular, I'm interested in knowing if you have the surround on or off, what numbers you have the dials set to for treble, mid, and bass, and if you adjust the balance.
I'm hoping Mercedes didn't make a mistake by switching to Burmester...
My settings are, surround on, no adjustment to balance or fade, treble and mid at 0 and bass at -2. It sounds quite good to me, but everyone has different tastes and preferences.
I get to drive a new W205 on weekends with the new top spec Burmester sound system and always then look forward to getting back into my C204 for the weekly daily commute with the Harmon Kardon that sounds a lot better even without having to adjust anything at all, with this new Burmester I've tried heaps of adjustment and still it sounds inferior...but is supposed to be better go figure
However the Bass is absolutely woeful and the fact that listening to audio through a USB cable to the iPhone is the only "good" way to listen to it is so poor. Normal DAB/FM just has no bass to it - even if maxed out at 10. It sounds like its stuck on 3 compared to via the USB/iPhone. Even using Bluetooth the sound just sounds so inferior compared to USB.
I run my settings at -4 -4 10 to get any decent deep sounding output. I listen to EDM a fair bit so it does make it sound a little woeful. Even then the bass is really short and very full/smooth.
I have also noticed that slight volume adjustments can impact the bass processing and suddenly it can go from sounds pretty good to suddenly missing bass without any setting change. I just wish we could access the full EQ for each audio input!
Plus the vibrating speaker issues is just so poor - any audio book is just unbearable to listen to for a long time as it happens on certain sounds or words only (and unexpected).
Very disappointed in the sounds system for a car that costs this much.
