Brake pads
Finding brakes for this vehicle is absolutely painful.
I have the Carbon Ceramic Brake package, my brakes are oxidizing already and the vehicle only has 7,000kms on it. Only one track day... I have been searching for aftermarket brake rotors and brake pads.
So far the only place that makes brake pads for the carbon ceramics up front are Pagid, I believe it is the RSC 1. Even when you search for them, they are tough to find. They are $950USD
If you are looking for rotors, there is no one out there that I can find that have rotors for our vehicles. I have a couple companies that I'm trying to work with to make iron rotors to replace the CCB's for track days. Also found a couple companies in the UK that actually refurbish your carbon rotors for about 1000 Euros each. www.sicom-europe.com
There is another company in Europe that is supposed to make the hats to attach to the rotors... Then you can use AP Racing rotors. One issue that we have with the carbon ceramic rotors is that the depth and therefore the pad size, is pretty wide and doesn't fit most standard rings.
I also have an email into Carbotech and Performance Friction to see if they have anything up and coming for our cars.
I will keep you all posted. Hopefully one of us finds something... It's amazing how much stuff I can find for an F80X, not much for aftermarket on our vehicles!
Confirmed Pagid does make pad replacements for CCB.
Pagid has RS29 pads that are very high performance but they're noisy / squeaky as a race pad.
Carbotech makes pads for our cars. They have the XP8, XP10 and XP12's. Check them out. They have been great to deal with. Super responsive, even asked what tire I was running to recommend the best brake pad!
Will most likely be running the XP10's.
Thanks.
Kurt
I installed them on my W205 last season for an event and they were a perfect fit as they are using the exact same caliper. The front pads I used are Endless EIP162MX72.
Rear pads are of course different and dont fit the W205
I swap back to the OEM pads for Street use.
It may be that the W204 and W205 OEM pads may be using a different compound hence may have different part numbers but I can assure you that the physical size of the pads are the same.
Thanks.
Kurt
Ill report back on brake dust since I've only been driving on them for a day, but so far it's looking good. Usually after driving for a night I'll need to wipe off my rims because of brake dust. With the R4-S I haven't noticed any yet.
