Lowered approximately 30mm on KW HAS, K-Mac Camber kits F&R, 275/35/19 AR-1’s on 19x10.5 R & 325/30/19 on 19x11.5 R no spacers and yes rolled rear guards.
That looks great. Checked out your Instagram account and saw you have some pretty good mods done, including larger turbos. What turbos are you running and how's the traction with your wheel/ tire setup?
Thanks, PTG turbos and tune.
Got some fine tuning to do and traction is great thanks to you the thick sticky tyres.
Looking to tune for e85 or e50 so need all the help in the traction area as I can.
My sedan is 860hp and I run 305 AR-1’s on that which work well.
I am currently running Nitto NT05's on a 2017 Coupe, the rears lasted 3,500 miles and really did not hold the power I make so had to pull boost in 1st and 2nd
Wondering if anyone has fit 315's in the rear? and looking for recommendations on rear tires, considering Toyo R888R's, Nitto 555R, and Goodyear F1 Supercar 3R's any others to consider?
Today Nitto NT05, but looking for max rear end grip!
F 275/35/19
R 305/30/20
Hey, did you install the 315 if yes please share your experience with us 😁
and is true that you have to install longer screws for the rim ?
I am running on 305/30/20 PS4S lowered on eibach springs. Have a rubbing issue in the rear (wheels are 20x11 +50 offset). Instead of going back to stock springs, anyone know if running an adjustable spring kit (ie KW, H&R etc) in rear rear set to max height would work?
I’m trying to determine if the max height of an adjustable kit is high enough to decrease/remove my rub. What’s interesting is my left side rear does not rub but the right side rear does. I feel like if I can add even just 1/3 or 1/2” of additional height, it will
solve my issue on the right side.
I own a c63s coupe, and I just want to know what the maximum size for the tire in the rear its a 20 inch rim right now on stock it’s at 285/30zr20 It’s a stage 2 and the 4s are just not working for me I just ordered some Toyo R888 315/30zr20
But I’m afraid that it won’t fit.
plus I bought the long distance spacers too just in case Does any have an idea please ?
actually they did not so I just sold them to my friend which did fit his car perfectly it was a Zl1 so I just ordered another pair was a 285/35zr20 which made the car much nicer stance with the bigger frame wall and some spacers.
ah yes even the r888r 305/35r20 wont fit , too bad
