C63 Standard vs Performance Exhaust
Hi all. First post, so hello! I recently purchased my C63, unregistered prebuilt, got a great deal and dodged the waiting times, but it didn't come with the performance exhaust, which I'd have liked. So I have a few questions if anyone's able to answer them!
1) Has anyone heard both the standard and performance exhaust? How different were they? I looked under the car and noticed the standard exhaust has the valve on the H-pipe, but obviously not the ones in the back boxes, but how much louder does the performance exhaust make it? And how much quieter on the quiet mode?
2) Can the performance exhaust be retrofitted? Including the button? And, if yes, does anyone have an idea on cost?
3) Would it just make sense to get an aftermarket exhaust rather than retrofit the perfomance option? I prefer the idea of OEM, and I also like the idea of a switchable, preferably with the OEM button rather than a keyfob or something.
Thanks all!
Thanks all!
Not sure if this helps. It's a video comparison of the new C63s coupe with the performance exhaust valves open vs. closed. I would think that this performance exhaust system, with its valves closed, would closely match your configuration.
Andyroo (08-12-2016)
Pure Sound: 2017 Mercedes-AMG C63 S Coupe (Start Up, Revs, Acceleration & Drive Modes) - YouTube
2021 GLE53; 2018 Audi R8 V10 Plus
1) Has anyone heard both the standard and performance exhaust? How different were they? I looked under the car and noticed the standard exhaust has the valve on the H-pipe, but obviously not the ones in the back boxes, but how much louder does the performance exhaust make it? And how much quieter on the quiet mode? Performance exhaust definitely sounds better (louder), but if you talk to 5 people they will give 5 different opinions on how much better. I have the performance exhaust and it is rare that I drive with the flaps closed. The sound is intoxicating and makes you want more.
2) Can the performance exhaust be retrofitted? Including the button? And, if yes, does anyone have an idea on cost? Have not heard of anyone doing this. Would probably cost way more than just going with an aftermarket exhaust.
3) Would it just make sense to get an aftermarket exhaust rather than retrofit the perfomance option? I prefer the idea of OEM, and I also like the idea of a switchable, preferably with the OEM button rather than a keyfob or something. Unfortunately, I think the keyfob option is going to be your only option. The AWE Tuning exhaust sounds great - if I didn't have the performance exhaust I would definitely upgrade. However, with having it, I struggle to justify the cost to buy and install for making it sound somewhat better, but not dramatically better.
Just my two cents...
Alternatively, I could just get an exhaust guy to mod the backboxes—after all, the two mercy exhausts look the same from there forwards as far as i can tell.
Thanks!
I don't have performance exhaust on my car and like you, don't like the idea of have a key that I need to keep in the car. I went with the AWE-Tuning Track exhaust. Still waiting for delivery so no videos but its just loud all the time. It still has the H-pipe with the valves but deletes the mufflers so no extra set of valves. (My understanding. Also not expensive $1350.
Just been under the car and noticed that, compared to the performance exhaust, the standard exhaust has larger back boxes (mufflers). That coupled with the wider outlet for loud mode makes it overall louder than the standard.
Just a thought: wouldn't it be cheaper just to have someone make up a straight pipe for you to replace just the rear boxes with rather than get a whole new system? As far as I understand it, the standard exhaust has the h-pipe valve (opens in Sport+ and adds pops and bangs), and the rear boxes are sleeved and clamped on, so could easily removed and replaced?
You could certainly do what you suggested with the straight pipes, however aftermarket exhausts you are also getting larger diameter pipes for a deeper growl.
Retrofitting would be tough as people have said above. You would need to wire the button, run wires to the rear mufflers, reprogram the car to open and close when you change modes.
Here is a pic of the stock vs awe you can clearly see the difference
The normal exhaust does have the the H-pipe. It keeps the exhaust from droning as it opens and closes depending on RpM and throttle position. The pops and bangs are all created by the ecu. I was talking to a local tuner and he can make more or eliminate them complety when he flashes the ECU.
Fingers crossed the wiring for the performance exhaust is already in the room and unused—it could well be that the performance exhaust and the button are close to plug and play from the dealers point of view. I'll check with them and see what they say.
Edit: Wait, that's stock on the right? Where's the valve on the H-pipe? Mine has a valve there.
Interesting, thank you for the insight. I think the car's deep enough as standard for my tastes—really I'd just like more volume, and more metallic 'growl' if possible. Removing the secondary cats seems like the way to go for the growl, but I'm not sure I want to do anything permanent to the car...
Yes that is the stock on the right. There is two H pipes on my stock exhaust. One in the front had the valve and the one in the back(shown) no valve
Andyroo (08-14-2016)
You could certainly remove the rear mufflers and replace with straight pipes with no permenant damage. There is a break right before it splits off towards the mufflers. So you could bolt on the straight pipes right there and if you wanted to go back to stock just unbolt them.
I guess as well that a good exhaust guy should be able cut the cats out neatly enough to be able to replace them if needed down the line.
Thanks for your help! I'll report back on what the dealer says about retrofitting the performance exhaust as well.
