Winter wheel/tire setup
I ended up putting a set of Vredstien Wintrax on my OEM wheels and it worked great all winter.
Now as for winter setup the dealer or even local tire shop will recommend you go down size in front to 235/40/18 and put those all around DO NOT DO THIS! I had studded nokian Hakkapelitta 8 tires and in that size they were really unstable in the rear. I trusted my tire guy and he messed up (also the fact that since Hakka 7 the nokians have gone down hill).
I suggest you keep the oem 245/255 setup with ever brand you chose.
*** edit I just not noticed this is for the new model C63S my bad I was talking about the w204 C63PP.
Are there any low cost wheel alternatives?
I had the Pirelli's on my 911 4S; while they were fantastic in the wet, they were only so-so at best in the snow. I am trying to get word about picking up Nokians.
You should also have a good look at the Nokian Hakka 8s.
They make good, strong, quality wheels that are good for the winter. Most likely will need to order them from Canada.
What is the offset/width for the oem S wheel?
Thanks!
Working with my local tire specialist, there do not seem to be that many great tires for this car though. I do not recommend the Pirellis (great in slush, not so good in snow, expensive). I am very tempted to pick up a used 325/330xi for about $3000 off of craigslist and leave the C in the garage....
