C63/C63S AMG
Winter Tires on Coupe
Old Nov 1, 2016 | 10:20 AM
Tvall13's Avatar
C63S AMG Coupe
All,
I am getting the C63s Coupe shortly and am looking for winter tires for the stock 19s 255/35/19 front 285/30/19 rear. Tirerack has Pirelli Sottozeros for those sizes but I've never like them much. If I go to 35 sidewall in the rear you can get Michelin Alpin P4. Anyone have experience with those tires? Also, any reason I shouldn't get the slightly bigger sidewall? I would prefer more sidewall in the winter plus I don't see how it would be much different than having the optional 20" wheels in the rear.
Has anyone else found or recommend a better set up?
Thanks!
Old Nov 1, 2016 | 04:55 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Narrower is supposedly better for Winter so how about Bridgestone Blizzak LM-32:
245/40/19
275/35/19
Old Nov 1, 2016 | 05:17 PM
Tvall13's Avatar
C63S AMG Coupe
Isn't it best for ABS and traction control to not adjust the tire size that much? Especially the height and therefore revolutions per mile?
Old Nov 1, 2016 | 05:42 PM
E55 KEV's Avatar
Veteran: Air Force
Using this calculator https://tiresize.com/calculator/
For the rear diameter:
285/35/19 is +4.7% higher than stock
275/35/19 is +3.5% higher than stock
For the front diameter:
245/40/19 is +3.5% higher than stock
Old Nov 1, 2016 | 05:46 PM
Tvall13's Avatar
C63S AMG Coupe
Thanks. What is a good percentage to stay within?
Old Nov 1, 2016 | 05:49 PM
E55 KEV's Avatar
Veteran: Air Force
I guess the lowest percentage possible. Too bad no one makes these in winter they would prolly be ideal for your car:
245/35/19 -0.8% lower than stock
275/30/19 -0.8% lower than stock
Old Nov 1, 2016 | 05:54 PM
E55 KEV's Avatar
Veteran: Air Force
I don't know the wheel offsets but if the front wheel fits the rear investing in 2 additional front OEM wheels and mounting on back and using 255/35/19 all around may be something to consider.
Old Nov 1, 2016 | 07:07 PM
Tvall13's Avatar
C63S AMG Coupe
Thanks for all the replies. I did find Pirelli Sottozero II in my stock size and Michilen Alpin PA4 in my size for about $300 more than the Pirelli's. I'll probably go with one of those options.
