My C63S coupe is slow
Is there anyways I could make the traction better? Changing tires maybe? Do some ECU tuning?
If you're spinning the tires all the time then it isn't a power problem.
Sounds like you might want to get stickier rubber.
Slight increase but the car flys at the right temp.
Running Michelin PSS
Also, brand new tires have to get some wear before they hook up in the intended way.
All of which we have no info on.
A car with 500 hp does need to be eased into power in low gears..
They are factory fitted with different types not all the same, FYI you may want to go back and check what that car had fitted, otherwise just upgrade as most people do
This will fix the "not fast" feeling of the car lol the ECU software upgrade makes this car fly
We have anything from ecu tunes to turbo upgrades to make her really fly!
ECU TUNE
eurocharged c63s dyno tune
The tune is currently on sale, let me know if we can be of any help!
(trying to do a semi easy break in at least) and coming from my Infinit G37 it feels extremely fast. Never driven a C63 but that will change this summer at the AMG driving academy.
I will say I am becomming more and more unimpressed with the stock Continental run flats (feels too firm and too slidy/squishy at the same time), maybe try a different tire?
