C63/C63S AMG
Rattly pasanger seat belt
Old Dec 16, 2016 | 07:02 AM
michael640D's Avatar
2018 E63S,2016 C63 S Edition 1 Coupe(gone), 2011 640D M Sports Coupe, 2015 435i M Sports Coupe
Has anyone found the magnet on the UK performance seats in the coupe yet to stop the seat belt buckle banging on seat hard shell, as I can not seem to locate it what so ever on my Edition 1 seat????
Old Dec 16, 2016 | 09:19 AM
g5und's Avatar
C63S AMG Coupe
Here's a pic of mine on the magnet. Hope this helps.
Old Dec 16, 2016 | 09:25 AM
Thanks g5und will have a look tonight most helpful.
Old Dec 18, 2016 | 02:15 AM
SBH-'s Avatar
C63S 2016
should work out perfectly fine
Old Dec 18, 2016 | 09:18 AM
Found it although you have to put the seat right back as fare as it goes or put the seat back reclined other wise it does not say there ?
Old Dec 19, 2016 | 01:43 AM
SBH-'s Avatar
C63S 2016
if it doesn't work out, then you can always fasten the passenger's seatbelt ?
Old Dec 19, 2016 | 03:10 AM
That's another alternative SBH thanks
Old Dec 19, 2016 | 03:16 AM
SBH-'s Avatar
C63S 2016
np bro. but is it an issue with those who have the standard seats? don't think so ...
Old Dec 19, 2016 | 10:56 PM
JPS114's Avatar
2017 C63s Cab (DW/RP)
I didn't have an issue this AM on highway with top down but tonight after dropping off a buddy I started to hear the banging of belt.. Have to try the magnet tomorrow OR find a clip because ITS ANNOYING!
Old Dec 20, 2016 | 01:12 AM
SBH-'s Avatar
C63S 2016
either clip it to the magnet or just fasten the belt
Old Dec 20, 2016 | 11:46 PM
JPS114's Avatar
my OCD won't allow me to just fasten it in with nobody in it…
There needs to be a solution for this as it happened again today with top down, which is typically how i'm cruising around. And BTW the magnet doesn't work for S**T
Old Dec 21, 2016 | 12:59 AM
SBH-'s Avatar
C63S 2016
that's weird, cuz mine works perfectly fine !
Old Dec 21, 2016 | 07:18 AM
I agree does want to stay there when driving the seat belt tension is pulling it away from magnet all the time and when you hit a bump it comes off
Old Dec 21, 2016 | 08:19 AM
bra10j's Avatar
Aston Martin, Porsche, Alfa Romeo, Land Rover & Mercedes
I had the same issue on my saloon but Merc fixed it by fitting an addition buckle stopper (the plastic dot in the belt webbing) that now stops the buckle from hanging low enough to rattle on the seat.
It works in the saloon but looking at the heights in the coupe it may not be possible.
Old Dec 21, 2016 | 04:00 PM
Uga Uga's Avatar
2021 C63S coupe
I think they may need a stronger magnet for the Coupe, as the belt is set further back.
Old Dec 24, 2016 | 10:34 AM
JPS114's Avatar
UPDATE: Took my car to local dealer today for inspection of passenger seat belt knocking… they told me there is no magnet, which I suspect is wrong due to other post on this form. They also indicated that they could tighten up the tension on the belt, but i'm not sure how much thats going to stop from slapping back & forth @ 80MPH with top down..
Old Dec 24, 2016 | 10:54 AM
Mbm6f's Avatar
09 C63 AMG
My OCD was the same way, sometimes this would happen in my Audi so I just fastened every seatbelt and somehow that was more paletable to my OCD.
Old Dec 24, 2016 | 04:26 PM
JPS114's Avatar
honestly i waited 3 months and spent 6 figures i shouldn't have to compromise..
Old Dec 24, 2016 | 05:56 PM
Scarafin's Avatar
'16 AMG C63S Coupe
I had the same problem with my coupe.
The magnet is just not strong enough to hold the belt with even moderately
spirited driving.
I just push the buckle right up to the top and it sits there without any rattles.
When I get home later I'll try to take a pic. Now you will have to do this everytime you have a passenger that leaves the car, as the buckle will naturally fall down. This isn't really an issue for me as 99% of the time it's just me in the car.
Merry Christmas,
Scar
Old Dec 24, 2016 | 06:13 PM
Mbm6f's Avatar
09 C63 AMG
This is true
