C63/C63S AMG
C63 and C63s
Old Dec 18, 2016 | 04:11 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
C63 and C63s
Does anyone know the different between a base C63 and C63s beside $8K more for 39 hp extra hp. For around $2-4K with aftermarket tuned gains upward of 100 hp. So why would anyone want to pay extra $8K? I just can't do it.
Old Dec 18, 2016 | 04:19 AM
juse's Avatar
c63 coupe
its not about 39 hp
S version has dynamic engine mounts and composite braking system (helps to increase fade resistance and reduces weight)
Old Dec 18, 2016 | 04:23 AM
Souriall91's Avatar
2017 c63 Amg s (almost)
Also, standard leather interior in any color, 19" wheels, and the electronic rear differential. I think there's a couple other small things as well.
Old Dec 18, 2016 | 04:30 AM
juse's Avatar
c63 coupe
yeah
i forgot about diffrenetial
Old Dec 18, 2016 | 09:21 AM
BallzOne's Avatar
Mazdaspeed
Race mode
Old Dec 18, 2016 | 10:15 AM
Uga Uga's Avatar
2021 C63S coupe
In day to day driving, I doubt if the lay person would be able to feel the dynamic engine mounts and electronic differential at work. The S hasn't got composite brakes, just larger ones.
Of course it's your money and ultimately your call.
I went for the base model and used the savings on options that I will use everyday and appreciate.
Here is the non S in action.
Old Dec 18, 2016 | 04:25 PM
tekfoc's Avatar
Veteran: Army
18 E63S
great video .
Old Dec 19, 2016 | 02:49 AM
juse's Avatar
c63 coupe
it has
Old Dec 19, 2016 | 08:19 AM
Uga Uga's Avatar
2021 C63S coupe
Originally Posted by juse
it has
Are you sure? Ceramic composite brakes is an OPTION on the S. at £4,285.00
The OP I believe, is comparing both cars without options.
Old Dec 19, 2016 | 08:32 AM
juse's Avatar
c63 coupe
Are you sure?
yes I do 100% sure
you muddle it with ceramic brakes
http://mercedes-amg.com/engineering....g=eng#/control
scroll down
AMG High-Performance Composite Braking System
and
AMG High-Performance Ceramic Composite Braking System
these are different things
Old Dec 19, 2016 | 08:44 AM
Uga Uga's Avatar
2021 C63S coupe
yes I do 100% sure
scroll down
and
Thanks. I stand corrected. AMG Website calls it compound.
Old Dec 19, 2016 | 04:19 PM
unagi1's Avatar
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
A lot of the options on the S are either standard or reduced in price (wheels, upholstery, steering wheel, etc.) and lessen that $8k or so delta.
That said, the non-S items (no dynamic engine mounts, mechanical diff) probably make it more involving (aka difficult) to drive. The C63S is definitely easier to drive the car in corners, rough and wet roads as opposed to my 507.
