Cat/less Down Pipes - Feedback Please
I live in Ga and in my city there are no smog checks
What companies are supplying Right Hand Drive 2 piece dump pipes?
Links, info, pricing and pictures would be great.
Thank you
Keep in mind, an open exhaust isn't/shouldn't be what gets you the pops and crackles. What those are are backfires. Excess unburnt fuel dumped into the exhaust after you've let off the throttle. The exhaust is hot, so it ignites, causing an explosion, and hence the loud pops you hear. AMG has simply actually tuned for this to happen. So when you go into Sport+ mode, not only is it a much more aggressive fuel map (for more power), but it allows for that overfuel delivery to allow for the backfires in the exhaust.
Yes, every now and again with hard acceleration followed by unexpected deceleration you may get a pop here and there. But you won't get it without the tuning.
And if you run straight open pipes, there won't be a restriction (cat), so you'll end up with fireballs and even flames (depends on just how much fuel you're burning/wasting).
