C63/C63S AMG
285's on a sedan
Old Jan 4, 2017 | 08:39 PM
Souriall91's Avatar
2017 c63 Amg s (almost)
285's on a sedan
I know there's a bunch of threads about tires but I need a definitive answer on the tires. I have stock 19" wheels and want to go in and order 285's tomorrow. Plus I know this will be helpful for others. As far as fitment goes, do 285's fit without spacers? Or do I need a spacer so they fit? Also, what size should I run, 285/35 or 285/30 or 285/40 for rotating circumference? Thanks in advance.
Old Jan 5, 2017 | 01:58 AM
SBH-'s Avatar
C63S 2016
I'm planning to do the same, lets wait and see what the guys recommend.
Old Jan 5, 2017 | 01:10 PM
bgm130's Avatar
2016 C63S
my friend was running 295 R888 in the rear of his sedan. he was using the stock 5 spoke 19" wheels. no rubbing issues at all. i cant remeber if they were 30 or 35. he didn't run spacers either.
Old Jan 5, 2017 | 03:08 PM
msd3075's Avatar
'15 C63S
295/30-19 would have be closer to the aspect ratio to the stock 265/35-19. It's a little shorter than stock, but closer than 295/35-19 would be.
Old Jan 5, 2017 | 04:59 PM
black63s's Avatar
2018 750i Msport, 2018 Range Rover Autobiography, 2019 C63, 2017 F Type R
The r888 is a 295/30-19. I am ordering a set of 285/35-19 Bridgestone Lorenza re-71r to go on my 19x9.5 hre wheels in the rear so I'm interested to see how it goes. The salesman at discount tire says there systems shows a 275 as a potential rubbing issue but I do not believe that.
