stock c63s sedan exhaust setup
Turbos—>Downpipes (with primary and secondary cats)—>mid pipes (with valved h-pipe connecting them)—>axle back pipes (with non-valved mufflers on non-perf and valved on perf)
To get more noise you can:
1) fit a cat-back exhaust (which joins after the downpipes)
2) fit an axle-back exhaust (which joins after the mid pipe)
3) remove the secondary cats (which involves cutting them from the downpipes)
4) replace all the cats (which involves switching out the downpipes for catless ones)
Pros/Cons of Each
1) Deeper sound, easy to fit, cheaper than downpipes/less raspy than downpipes
2) Deeper sound, really easy to fit, cheapest option and easy to make from scratch (I'm getting them made and fitted to my non-perf for £300)/not as deep as cat-back, less raspy than downpipes
3) More volume and rasp, cheap to have cut out and replaced with straight pipe/involves modifying factory downpipes irreparably
4) Closest sound to non-turbo/costs a lot of money for the pipes and to have them fitted, because the standard downpipes must be cut or the transmission dropped to get them in.
Hope that helps!
Pros/Cons of Each
Hope that helps!
