C63/C63S AMG
c63s subwoofer install
Old Feb 10, 2017 | 10:19 AM
Modio1234's Avatar
2016 C63S AMG
Does anyone know how to wire into the c63s factory amp to connect to a subwoofer amp? What wires do i need to tap into.
Old Feb 10, 2017 | 12:06 PM
M177ED1's Avatar
C63S EDITION 1
In previous cars I would tap the existing audio cables. You might be able to do the same and just run cables to a bigger aftermarket sub since the stock system has a dedicated sub (so no need to 'filter' out the highs) which is under the driver side (LHD) foot well (I believe)
Old Feb 10, 2017 | 01:08 PM
AMG 17GT's Avatar
R Nine T
JL audio makes a factory connect called Fix 82 I believe. Check with them.
Old Feb 10, 2017 | 01:33 PM
Mikey_boy's Avatar
2017 C63s Sedan | 2016 Yukon XL Denali
Tons of great information here. He did a ton to the audio. Important to note that we do have factory subs and you can tap those from the back and use as the source for your amp. The Fix82 will help for sure, but I think it's more for if you're going to power ALL the speakers in the car.
I'm planning on running a single sub in the trunk put in the space on the driver's side. It'll have to be a custom fiberglass.
Old Feb 10, 2017 | 01:41 PM
Modio1234's Avatar
2016 C63S AMG
Yes that is what im trying to do tap into the original woofers thats what i did on my 14 audi a6 and it worked great unfortunatly i cant figure out what wire is what in the back of this car. All i see is what i think is the stock amp and connected to it is a blue cable that looks like it is fiber optics and a black plug with yellow and orange wires coming out of it.
Old Feb 10, 2017 | 02:19 PM
Mikey_boy's Avatar
In that page I sent, there is a wiring chart that might be able to help. I haven't gotten into the project yet, so I haven't really looked around.
Update this thread when you find it please.
