Exhaust Rattle C63S coupe.
#176
Not sure how much truth there is in what I have been told but apparently they use a special grease. Given that exhaust temps can exceed 1000 degrees (at the dump pipe), you might need to refresh that lithium grease fairly often. Might want to try high temperature grease instead.
Edit: Sanity check on the last thing because I remember hearing it years ago... "Our research shows the crossover pipe is generally good for a few horsepower, the torque curve generally comes in earlier and the sound drops between 2 and 6 decibels. In most cases it will also take that dreaded highway drone and convert it to a purrrrrr. That’s a lot of benefit for one small modification."
#177
I have this rattle as well on a 2017 C63s.
One could say it sounds like wastegate chatter.
On the C63s it is spot on 3rd gear and gradually accelerating. It only seems to happen at the exact revs that were mentioned by others. I do wonder if permanently closing the H-pipe flap will disturb the car's balance?
Regards
George Lisciandro
Regards
George Lisciandro
#179
If you are out of warranty, you can either upgrade to an AWE Switchpath exhaust or if you don't want to, you'll need to weld the H-Pipe flap and plug in a AWE simulator to prevent the engine from going into limp mode and throwing a CEL (Check Engine Light).
You can try to grease it but I don't think it will last long.
What I want to know is if the H-pipe is welded shut, will it disturb the car's balance, performance or cause droning? This is why I'm reluctant to do this. Perhaps @untamedd knows?
Regards
George Lisciandro
#181
I have the same exact thing happening to me in every gear, before i had the actuators replaced and now 500miles later it came back even worst. I will cut out the whole valve and weld the H shut. Waiting for my AWE sim.
#183
Ridiculous. You'd expect more from AMG.
I'm looking at cutting out my H-pipe, blocking it off and plugging in the simulator too. Do you think getting the H-pipe closed off would create drone or ruin the sound of the performance exhaust? This is the only thing that's worrying me.
George_1992 (02-01-2020)
#189
Hi guys, i want to update on my previous post. So i didn't touch the h pipe (even tho i have the awe sim in the glove box) , but instead i went full catless and i cant even hear the damn thing rattle. 😁😆👍
#190
Hi guys,
Had the same fu**ing rattle on my 2016 C63s coupe and it was crazy annoying My MB dealer here in Russia didn't help me so I decided to "tune" my exhaust.
I made my C63s catless (bought downpipes) and just pluged OFF H-pipe valve and made it CLOSED forever by welding it in closed position. So now I have very loud exhaust and no rattle!
The only one problem is CEL error, but gonna fix it by going Stage 1 or Stage 2.
Hope it will help someone! Greetings from Russia
The following 2 users liked this post by c63s_brutal:
hookson (04-20-2020),
Jimmy_c63s (08-17-2020)
#191
Escape
[QUOTE = untamedd; 7883315] sí, la mía se parece a esa imagen. Fue fácil para mí, ya que me habían quitado la válvula, así que solo podía insertar el disco en el medio.
ps nada malo en tratar de hacer que se vea como acciones como sea posible, pero el concesionario se verá en la soldadura y decir que no es la acción de modo que eso es algo a tener en cuenta también. [/ quote]
Hello guys . same problem in my car. and I have started reading this great Forum that thanks to you things are easier. I also want to cut pipe H but I'm not sure where to cut it and if the motor that closes and opens the valve, does it have to stay there or disappear? it will give me error and I have to buy the AWE simulator? thanks
#192
Hi all,
I had the rattle start after my secondary cat delete and only with the performance exhaust button turned on (the loud button). Only ever heard it with ~30% load, in 2nd and 3rd, between 2k and 3k revs, going both up and down through the rev range. I could make it happen in 4th at those revs but only using about 60% throttle.
I was hesitant to have the H pipe welded shut as I expect it does more than control sound (could be wrong), so I had my mechanic pull out the valve, lube with high temp grease, heat and stretch the spring holding the valve and putting it back together (1 hour all up). The valve doesn't just bolt off - it is more of a pull to remove it. Sorry, I didn't take pictures while he was doing this cos I was too busy looking under the car at my front tyres which are due for replacement at 12,000kms (f&*k).
After 2 days, there is still no noise (I will keep the group updated if it comes back). I suspect the spring stretch provides some additional firmness which is what it needs so that the butterfly valve doesn't flap under those ~30% load conditions.
Hope that helps.
Hope that helps.
#193
700HP Facelift converted PFL C63 S Coupe
Please tell us how you go!
I think you're onto something with the "spring stretching" technique because when I lightly did this on mine I noticed the rattling noise completely disappeared for two weeks (but returned I'm guessing because because I didn't stretch the spring too much).
Last week my Mercedes dealer ended up doing the standard lubricate on all of my valves. I'm out of warranty but they did it for free, and it has been fine. They're really good at the dealer I go to in Miranda, Sydney.
If it comes back, I'll stretch the spring on my H-pipe valve even further.
There's a TIPS DOC G149.10-p-064223 regarding the issue and is well known by Mercedes-AMG so even if you are out of warranty they will sort it out.
#195
Nah it's not the wastegate in this car that causes it. I know what you're saying because i've had wastegate "chatter" in other cars before but as explained in the previous posts the problem we're all having with the C63 here is the actual H-pipe flap that rattles.
#196
So my rattle is still there and I'm learning that Facelift C63s owners are now complaining of the same thing on their cars too which is a shame 👎
Heading back to Mercedes again this month to assess the ongoing rattle from my H-pipe and this time they will try to do a "goodwill" (out of warranty) case for me to get the part changed instead of just greasing it. I hope Mercedes will do the right thing and honour a replacement.
After the grease failed to fix my issue I was thinking of just buying it myself and applying it whenever needed but at $120 AUD per tube (part no. A0009899151), I don't think so.
The alternative product for this is Castrol Molub-Alloy Paste TA but I can't find this in Australia anywhere.
Anyway, I'll report back here in case others have this same problem in future.
PS: Here is the paste that they apply A0009899151
jopsis_c63s (08-23-2020)
#197
Thanks!!!
My mechanic put me on all three flaps yesterday, grease he uses on his race car.
The noise is gone.
#198
#199
And his dealer is Liqui Moly, so I imagine he uses from that brand.
