Exhaust Rattle C63S coupe.
What did you heat the spring with? Did you "pull" the spring outwards while it was heated to expand it more so it's a tighter fit when you install everything again?
This is mine at the moment.
When you heated the top of the spring, did you need to heat it until it was red hot in order for it to be deformed? I just don't want to overdo the heating and completely destroy it 😅
The car loses its growl if you keep the valve open.
i know this because initially I thought keeping the valve open would equal max sound but like you said the car lost its growl.
welded a metal disc in between after and voila all the growl was back without the annoying rattle.
This H valve is just too faulty. Even the one I got with the AWE Track exhaust started rattling. Could have ordered a new pipe under warranty but wanted a more permanent solution so fixed it the same way
honestly i dont know the technicalities since im just speaking from the experiments I did from which i can conclude:
The H valve actually closes under load to change the tone of the sound giving it that growl (confirmed via the fact that a welded closed H valve sounded much more rowdy than a fully open one)
Does this happen to everyone?
Thank you.
Thank you.
Mods please merge topics.
After over a year with this rattle i've finally decided to be done with it and get it welded shut.
I've got my secondaries removed but wanted to ask you:
• Did welding the H pipe "closed" cause any drone with a secondary cat delete?
• Does it cause any difference in sound in full comfort (quiet) mode?
• And did it make cold start any louder (I don't want that).
Thanks mate.
Thanks mate.
How about in full comfort mode with the exhaust flaps set on quiet? With the the H flap permanently welded shut, did it sound normal to you in full quiet mode? Only asking cos even though I have secondaries out, I always use comfort mode with exhaust on quiet when driving around my elderly mother to her appointments 😆
https://youtu.be/6_Yhp1Mbbe4
