Eurocharged downpipes / tune review with video - C63s coupe
I don't think Philip @ EC would mind me quoting him on this. If he does, I will delete the post.
His quote when he sent me the attached dyno was 'Attached is graph, remember, I had nothing but wheel spin down low, I am very confident in your torque being over 600ft/lbs (: but the curve I am very happy with and we will work more on the development when Jerry’s turbos get here!'
On a prior email his quote was 'These turbos spool up very nicely and I have all kinds of wheel spin down low that I can't avoid on the dyno no matter how many people I get in the trunk (: '
I am content for the time being but think they will get more out of these things with some testing and development. I told them they could use mine as a guinea pig but they said they would rather abuse their car than a customer's car! I am anxious to see the results we can get after they do some further testing.
It does drive much differently than before. Not too noticeably different in the low end but it sure has woken up on the top end. Arguably the delivery is smoother and more controllable making it overall easier to drive. It is almost deceivingly quick now. You don't think you are doing much and then look up and you are at 100+ mph.
Jkob5 - if you are considering it, it is well worth the money. I personally have a BMW and that is how I became aware of PURE but had not done business with them prior to now. Jesse and Carol at PURE were fantastic to work with and they did an amazing job on getting these things turned around in just a matter of days so we weren't without the car too long. You already know how good Eurocharged is. Given the price point of this package, you just can't go wrong.
I did a very little bit of VBOX testing on the way home to Dallas from Houston when I picked it up and made 4 or 5 passes on a crappy back road about an hour north of Houston.
It is important to keep in mind that it is an Edition 1 Cabriolet which is code for this thing is as heavy as Shamu....its curb weight is 4226 lbs (i think this is about 200lbs heavier than the coupe and close to 300lbs more than the sedan) and I did these runs with a full tank of gas. Add to that I am no lightweight myself weighing in at around 225lbs. Keep that in mind when considering the below VBOX data. Also, keep in mind this is 'real' life data... not on a prepped track and with OEM tires at 40 lbs no less!....and with a driver (me) that hasn't figure out how to launch the thing worth a darn.
The best 60' time I could muster was 2.15s. Nonetheless, I did 7.7s @ 99.9mph for 660' and 11.6s @ 129mph for 1320'. Not terribly pleased with the ETs but I am happy with the trap speeds. If I can figure out how to launch the thing, I would be happier with the ETs. Had one 0-60 mph run at 3.6s and consistently doing it in 3.7s. 5-60mph is 3.5s. 0-100 mph is 7.7s.
I will admit those aren't earth shattering numbers but given the conditions, I am pleased. Undoubtedly those numbers can get better but I wanted to at least give you a 'real' life perspective from a 'regular' guy. This isn't a shop car or a dedicated track car, this is a real life daily driver.
I am going to throw some good tires on it and head to a track some time in the not too distant future. I am confident that a coupe or sedan with the same setup at the track would certainly flirt with, if not break into, the 10s.
Hope this info helps you make your decision. Let me know if you decide to go the PURE route.
Pure Turbos are very reasonably priced compared to some of the shop modded turbos making for a better priced Stage 3.
Were the tune modified for the turbos or were they just bolted on and running your stage 2?
PURE says you can just bolt up and doesn't need a custom tune but EC did a custom tune for me.
It's deffinately a better priced package for all to vonvider.
