Pure Turbos Stage 1 M177 Turbo Upgrade - dyno and slips
Removing turbos does not make the downpipe install any easier. The DP's are v-banded at the turbo, so it's actually very easy to disconnect from the top. The problem is that you cannot snake the downpipes out without a) cutting them in half or b) dropping the transmission.
Oddly enough, a turbo swap looks to be much easier than installing downpipes on this platform.
I was told that they will be fitting their turbos to a customers Eurocharged Stage 2 Tuned car in the near future so I'm siting to see these results.
https://www.instagram.com/p/BSy-rwCjkyK/
Ive never seen one so would be good to see.
https://www.instagram.com/p/BSE4yigDSxR/
https://www.instagram.com/p/BSJW404Do6l/
https://www.instagram.com/p/BSO5D9uj-8a/
http://www.pureturbos.com/store/merc...de-turbos.html
I'm considering Pure 900 Turbos. The only negative post I've seen regarding Pure Turbos was from improper installation.
I am interested to know more about Pure 900 Turbos and their reliability.
Am thinking that I could install the turbos and use HP Tuners MPVI2+ to tune. I am not looking for a maximum power tune. No knock, reliable tune for my car. Which I use as my daily driver. I just want the car to have plenty of kick, you know just because.
I tried Weistec W.1 Tune but it doesn't work on my car without getting CEL. I swapped out ignition coils and put in their recommended 0.022" gapped spark plugs. I'm not a professional technician or tuning expert but it looks like the timing curve is over advanced. Using live mode on Autel MS906TS I observed knock sensor registering knock before getting CEL. No error codes get recorded. It also crashes the rev limiter in 4th gear and beyond. Transmission doesn't want to shift, I have to manually shift it.
I would have to buy HP Tuners MPVI2+ for data logging for Weistec to fix the tune I bought. Which I think is rubbish since it was $3K. I'm sending back the handheld tuner and maybe I'll get a refund. Sure the car is quicker, until the CEL comes on and I have to pull over on the highway to turn the car off and on again.
I don't want to remove stock DP or add meth injection, I just want to run on pump gas. Is it unrealistic to think I can install the Pure 900 Turbos and have a faster yet reliable car?
