C63/C63S AMG
Battery tender???
Old 04-19-2017, 12:22 AM
FDNewbie's Avatar
'17 AMG C63S Edition 1 Coupe, '18 AMG C63S Convertible, '19 AMG GLS63
No...mine's not getting any repairs/maintenance. It's getting an "upgrade"...
Old 04-19-2017, 08:55 AM
auditoamg's Avatar
C63s
Um.... Dare I ask?. Ok... I will. Can you narrow down the term "upgrade?" LOL
Old 04-19-2017, 11:57 PM
FDNewbie's Avatar
Lemme just make sure it works...and then I'll post about it
Old 05-05-2017, 02:34 AM
FDNewbie's Avatar
Ok car's back. Man...I dunno why they didn't make it easy to lift up and remove the hard syrafoam type material in the trunk. Everything's tucked away and under other trim nearby...sheesh.
Mine's Part # A 001 982 81 08. Written on the left of the battery label is "VRLA/AGM". And a quick Google search confirms the same: http://www.ebay.de/itm/ORIGINAL-MERC...-/182073698292. So that answers that.
Ironically, just under it, written in Arabic (and not written anywhere in English on the battery lol) is the following warning: "Do not charge the battery via a battery charger except after disconnecting the battery from the vehicle electrical circuit." Hmmm... I wonder if that only applies to charging directly at the battery. Cuz there's obviously a charging/battery maintenance + and - post under the hood...
On another note, is that long thin cubby area in front of the battery made for a canister like Fix-A-Flat?
tekfoc (05-05-2017)
Old 05-05-2017, 04:51 AM
tekfoc's Avatar
18 E63S
You removed the aluminum cage around battery
were did you unbolted it from ?
the bottom ?
Old 05-05-2017, 09:28 PM
FDNewbie's Avatar
Aluminum cage? All I had was that thin styrafoam typa stuff that covers the entire trunk. Then there's actual styrafoam that covers the front edge of the battery to keep it in place/prevent it from wobbling around. No aluminum cage... ??
Old 05-05-2017, 09:43 PM
  #32
tekfoc's Avatar
18 E63S
Wow
here is a picture of one exactly like mine
Old 05-05-2017, 10:07 PM
  #33
FDNewbie's Avatar
Weird....you even have some stuff (two neon green/yellow items, one to the left and one in front of the battery), and something else in the cubby in front of the battery that's empty on my car. Mine is a C63S Edition One Coupe, FYI.
Here's exactly what I see, in order:
Styrafoam-like trunk flooring
With that layering removed. You can see the actual styrafoam piece holding the battery in place
Closeup of the battery and styrafoam piece
Syrafoam piece removed, and laying up (at the bottom of the pic)
Old 05-05-2017, 11:16 PM
  #34
tekfoc's Avatar
18 E63S
I have the same plastic cover as you but once I remove it
I have the aluminum cage holding my battery in place .
looks cool but a lot of work to remove.
my car is a 16 C63S sedan built aug 2015
Old 05-06-2017, 07:31 AM
  #35
FDNewbie's Avatar
I wonder if it's a difference between sedans and coupes? auditoamg has a coupe; maybe he'll chime in as to how his battery is secured.
Old 05-06-2017, 09:49 AM
  #36
auditoamg's Avatar
C63s
If I recall, it's Styrofoam... 😀
Mine is buried under a subwoofer at the moment, so harder to check....
Quick Reply: Battery tender???
